Patching Foundation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By mtmprop
Old 04-29-2019, 10:00 PM   #1
Rewards Points: 26
Patching foundation
have areas of an old cinder ash foundation wall that need repaired. Some are large areas of several inches deep. Is concrete patch the proper product for this. due to the large areas I was going to use metal lath fastened into the foundation then fill it in
mtmprop is offline   Reply With Quote
Old 04-29-2019, 10:23 PM   #2
retired framer
Rewards Points: 106
Re: Patching foundation
Can you post some photos of the problem.
Do not use flat bottom gables with scissor trusses.
Old 04-29-2019, 10:33 PM   #3
Rewards Points: 26
i will take some and post
Nealtw likes this.
Old 04-30-2019, 08:25 AM   #4
Rewards Points: 60
You would not want to use a patching material stronger than the cinder block. You may want to use a type "O" mortar mix for the patch material.
As for the Metal Lath if the block has been painted or covered with another material than you would use the Lath if just plain block skip the Lath it would cause more problems than it would correct.
ClarenceBauer is online now   Reply With Quote
Concrete foundation for damming spring Pack25 Concrete, Stone & Masonry 4 08-10-2018 06:53 AM
No Footer Beneath Foundation Wall Adam Sinke Building & Construction 5 07-24-2018 04:12 PM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 03:51 AM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 11:22 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
