Patch Hole In Concrete Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By joed
Old 02-25-2017, 01:40 PM   #1
Rewards Points: 8
Patch Hole in Concrete Wall
Hi all,
Continuing with small repairs in a basement for a family member. Stumbled upon this "wonderful" find.
When an addition to the house was made several years ago, a plumber had punched a hole through the wall in the basement (drywall, insulation, and straight through the concrete to dirt) in the basement. After asking around, it sounded like they chose not to run a pipe there, moving to a different location. He was supposed to fix it, but instead I found a pretty "grody" pillowcase shoved into the void. The hole is about 1.5ft in diameter.
Planning to somehow refill the hole with new cement, or cover it with cement board before repairing the drywall but I wanted to ask, any tips or suggestions for the repair? Is there a different material or method I should use? Very concerned about moisture here.
Thanks!
-EF
electronicsfrea is offline   Reply With Quote
Old 02-25-2017, 02:06 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Patch Hole in Concrete Wall
Hydraulic cement.
Should be available at your local supply outlet / lumber yard.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-25-2017, 02:12 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,526
1.5 foot diameter hole needs some concrete bricks and mortar to fill. That too big a hole for just hydraulic cement.
jlhaslip likes this.
The Following User Says Thank You to joed For This Useful Post:
Msradell (02-26-2017)
Old 02-27-2017, 04:17 AM   #4
Rewards Points: 2,810
joe d's got the right idea,,, hydraulic's the wrong material - its expansive cement due to the alum silicate it contains therefore short-lived,,, yes, you could DO it w/hydraulic but rapid set's much better material for this use,,, mortar in some doobies & finish w/mortar over the top (face) of the patch,,, then mud & drywall patch
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 05:53 PM
Finding solid wall behind tiles to mount pedestal sink! miamicuse Building & Construction 2 06-19-2016 07:23 PM
Mounting 60" LCD to thin concrete wall flatblackstrat Concrete, Stone & Masonry 7 02-18-2013 08:21 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 12:34 PM
