Parging Interior Of Brick Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By stadry
Old 03-19-2017, 08:57 PM   #1
Rewards Points: 48
Parging Interior of Brick Wall
What do folks think about parging over the interior surface of an above-grade structural brick wall? In the case that mortar is deteriorating throughout much of the brick wall, seems like it would be a faster solution than repointing every single joint.
I'm referring to the technique shown at 4:35 in this episode of This Old House:
https://www.thisoldhouse.com/watch/c...rowhouse-blues
Ultimately they end up framing a wall inside of the parged brick, spray insulating, and then putting up blueboard+plaster to finish.
Lots of posts on here about letting brick and stone breathe, especially older brick like in the old Boston and Philadelphia rowhouses. But as long as it can breathe to the exterior, would you think a parge coat like this one cause any issues?
cb_philadelphia is offline   Reply With Quote
Old 03-19-2017, 10:45 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,776
Re: Parging Interior of Brick Wall
I prefer exposed brick walls myself. Love the look of it.
How bad is the mortar?
Old 03-22-2017, 05:09 PM   #3
Rewards Points: 2,698
tommy doesn't live there OR own it,,, while owner's budgets often dictate mtls/methods, i think tom's reputation influences many decisions,,, i'd feel more comfortable knowing a prof eng had blessed the method,,, whatever you do, treat the outside w/silicone siloxane to wtrproof the brickwork
drilling holes in brick & epoxying in threaded rod's a liteweight method to me when tensile (lateral) movement exists or can be anticipated but that's just my opinion
Windows on Wash likes this.
Old 03-22-2017, 06:01 PM   #4
Registered User
Rewards Points: 526
If you waterproof the outside; add the lime-based sacrificial parging to the inside, or vice-versa, Figs. 4, 5, and 6: https://buildingscience.com/document...all-sacrifices
Gary
Old 03-27-2017, 11:59 AM   #5
Rewards Points: 48
Some great info - thanks for the replies.
I have not yet taken the plaster down in rooms that I plan to ultimately renovate, so can't comment on the condition of the brick and mortar yet. Still gathering info and taking time to explore options.
I can appreciate the need for the lime-based sacrificial parging. There's a heavy layer on much of the rubble foundation in my basement. Unfortunately, it's already made its sacrifices and I need to do some work to repair it in several places.
Thanks for the links - lots to consider still
Load bearing joining at brick wall. Studs where? corypa Building & Construction 2 02-07-2015 08:16 AM
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 02:55 PM
Parging interior foundation wall - Brick kingsley General DIY Discussions 5 01-16-2012 08:54 PM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 08:41 PM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 06:57 AM
