Ok To Pressure Wash Bluestone And Brick? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-26-2017, 04:49 PM   #1
Rewards Points: 36
Ok to pressure wash Bluestone and Brick?
Hi, I have a challenge at home this time of the year with plums by the dozen falling on daily basis and splattering over the bluestone. Very hard to clean. Was wondering if I could use an electric power washer on the bluestone safely? And if I do buy one, I would also be curious to know if I can use it on a brick patio I also have in my house.
As far as I know, the electric pressure washers, are not as strong PSIxGPM, as gas washers.
Thank you
skuba is offline   Reply With Quote
Old 06-26-2017, 05:31 PM   #2
JUSTA MEMBER
Rewards Points: 1,520
Re: Ok to pressure wash Bluestone and Brick?
My k- Archer electric came with several different nozzles.
I learnt that I needed to clamp a probe on the nozzle to keep me from getting too close to my Trex decking, but worked out a system with a 1/8 " welding rod and 2 small automobile gas line hose clamps, on the FAN spray to clean off birdie dodo., without mangling the surface.
So you should be able to prevent damaging your stone and bricks the same way.
6-8" prod should be plenty far away to stop the damage.
P.S. Those ripe plumbs make very good KICKAPOO JOY JUICE.
ED
de-nagorg is offline   Reply With Quote
cleaning excess mortar off bluestone and brick tarheelblue Concrete, Stone & Masonry 3 08-24-2015 09:29 PM
Need advice- Bluestone vs. Brick Paver Steps? lusterleaf Concrete, Stone & Masonry 4 04-03-2014 06:49 PM
How do you remove mortar from brick? JAYinMA Building & Construction 1 09-17-2011 08:10 AM
Capping Concrete Steps with Brick and Buestone??? bryankloos Building & Construction 0 07-06-2010 01:59 PM
Any good brick chimney water repellents? quigleybmd Roofing/Siding 3 04-12-2010 07:19 PM
