Most Appropriate Repair For Horizontal Crack In Foundation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By joed
Old 06-30-2019, 05:17 PM   #1
Rewards Points: 4
Most appropriate repair for horizontal crack in foundation
I have an 8 feet long horizontal crack in my crawlspace foundation and wonder if anyone has any idea what the likely cause is judging from the picture, and how it should be repaired. The crack is high up on the foundation and the crack line is not straight and there does not seem to be any moisture.
10ispardner is offline   Reply With Quote
Old 06-30-2019, 06:07 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 29,958
Re: Most appropriate repair for horizontal crack in foundation
It looks like a cold joint from the concrete pour. The lower section set too much before the second truck with more concrete.
ClarenceBauer likes this.
Old 06-30-2019, 07:27 PM   #3
Rewards Points: 1,042
That wall appears to be CMU's and a crack as opposed to a cold joint to me.
Canarywood1 is offline   Reply With Quote
Old 06-30-2019, 08:18 PM   #4
Rewards Points: 4
Thanks for comments. In either case, the crack is greater than 1/4". Is that due to the rebar corroding and the section needs to be replaced, or is there a better way to fix it?
Old 06-30-2019, 09:13 PM   #5
A polyurethane low pressure injection system is what i would use, as i doubt it's a structural problem, of course that's my opinion only, i'll post a link to a product that's well regarded for this repair.
https://www.concretenetwork.com/conc...urethanes.html
Tags
foundation , horizontal crack
