Mickey Mouse Addition = Wet Carpets - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By knight508
Old 04-23-2019, 05:52 PM   #1
Rewards Points: 28
Mickey Mouse Addition = Wet carpets
I have an addition that I believe to be custom made and it's had an issue I want to finally deal with. Whenever I get heavy rains the water finds it's way under the carpet near a wall. These pictures give a good idea of the layout:
https://ibb.co/tMJhmdF
https://ibb.co/6rcrhpv
I tore a little of the siding off to see exactly what stands between the carpet and the outside.
https://ibb.co/SXGHbCK
You see the plywood first and the darker bit on the actual concrete appears to be a 2x4 anchored directly to the concrete. You can see the big caulk bead I pulled back that was the only thing really keeping the water out in the past.
Any suggestions for a proper/permanent solution? I was thinking of taking off the bottom foot or two of siding to get at the concrete and cutting out a 1" channel all the way down the length of the wall.
knight508 is offline   Reply With Quote
Old 04-23-2019, 06:28 PM   #2
retired framer
Rewards Points: 4,952
Re: Mickey Mouse Addition = Wet carpets
The best fix would be to have the deck outside 2 or 3 " lower, any chance you would consider that?
Do not use flat bottom gables with scissor trusses.
Old 04-23-2019, 06:36 PM   #3
Rewards Points: 28
Unfortunately I don't think that would be too feasible as there's still another 10'-15' of concrete that goes out to the right and I have a deck above that.
Nealtw likes this.
Old 04-23-2019, 06:54 PM   #4
retired framer
There is a way to water proof the bottom of the wall with peel and stick and flashing but the door would still be a problem. so you would have to raise the door an inch and a half, there is usually a sill just above the door that can be removed to allow it to go up.
Old 04-23-2019, 06:58 PM   #5
retired framer
Tags
concrete water wet carpet
Mouse droppings in addition ceiling insulation roperman Insulation 4 08-28-2018 04:53 PM
What pitch should I make my addition. Roon81 Building & Construction 9 08-12-2017 01:32 PM
Framing questions for an single story addition Sbmmm Building & Construction 4 08-26-2016 11:53 AM
Master Suite Addition Design Captainjz16 Remodeling 6 06-30-2015 11:53 PM
Mickey Mouse job under my sink! tomme12 Plumbing 5 10-01-2010 12:22 PM
