Matching My Pavers? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-04-2019, 07:55 PM   #1
matching my pavers?
HI,
I recently purchased a new house and we have these pavers in the back by the pool. I would like to add some more to a walkway next to the house that lines up to the pool but I cannot find any of these at the local stores or online?
Does anyone recognize these pavers and/or know where I might order some? (Hopefully I attached them correctly!)
Thank you so much for your time
pdub is offline   Reply With Quote
Old 05-04-2019, 08:39 PM   #2
Rewards Points: 17,808
Re: matching my pavers?
With no location in your profile it's anyone guess where to look, you could be any place on the planet.
Who ever built this did not "order" them on line, they got them someplace local.
Old 05-04-2019, 08:46 PM   #3
Rewards Points: 492
Any loose ones? Should be a lot number and manufacturer on the back of tile. Fairly sure itís a Daltile tile but donít know the color markings.
BayouRunner is offline   Reply With Quote
Old 05-04-2019, 08:51 PM   #4
Hi,
I am near Orlando FL. I have looked at the local home depots and lowes with no success so far.
Old 05-04-2019, 08:52 PM   #5
Hi,
Yes I do have some loose ones.. I will check and see. Thanks
Old 05-05-2019, 07:50 AM   #6
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,226
pdub - those pavers did not come from HD or Lowe's.
take some really good photos, print them out on PAPER,
and show the photos around to some TILE and PAVER STORES.
also try to figure out how many square feet you will need. (they will ask you).
do not show people your cell-phone photos - - - - that is just so tacky.
also check with Pool Installation companies.
and - if you can contact the builder that built the home,
they may have the sub-contractor that did the pool work on file.
and as suggested, if you can remove a section to show the stores,
that would be your best bet . . . . but, very inconvenient to remove and
carry around with you. . . . . thus the good clear photos.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
Johnny_inFL is offline   Reply With Quote
Old 05-05-2019, 11:59 AM   #7
Any local brick and or Hardscape dealer should be able to help you.
Looks close to what you have.
https://www.belgard.com/products/per...ers/eco-dublin
Old 05-05-2019, 04:07 PM   #8
OK,
Thanks Johny_inFL,
I will check out some of my local paver and tile stores and see what I come up with. I will refrain from the cell phone pics
Old 05-05-2019, 04:08 PM   #9
Yes, the one looks very close to what we have. I think I can use those and substitute!
Thanks so much!
repair pavers captfl2x Concrete, Stone & Masonry 2 03-12-2019 05:57 PM
French Drain Under Pavers mbjg0788 Landscaping & Lawn Care 6 08-13-2018 07:58 AM
Travertine pavers driveway in cold climate Leopro Concrete, Stone & Masonry 7 01-04-2013 11:06 PM
Setting the footing height for pergola posts and pavers? blue sky Building & Construction 5 03-14-2012 10:34 PM
Pavers over a concrete sidewalk Beckerad Flooring 3 07-20-2010 08:59 PM
