Lines In Cement - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree10Likes
  • 1 Post By XSleeper
  • 1 Post By de-nagorg
  • 1 Post By Estranged
  • 2 Post By Nealtw
  • 1 Post By Nealtw
  • 2 Post By Old Thomas
Old 06-21-2020, 12:11 PM   #1
Estranged's Avatar
Rewards Points: 44
Lines in Cement
Just wondering if someone can tell me what these lines are in my cement it's not caused any problems they've been there since the cement was poured a year ago it seems they show up more after I wash it down, I did just recently added a cement sealer.
Thank you
Sent using my Umidigi Smartphone Via Tapatalk App
Estranged is offline   Reply With Quote
Old 06-21-2020, 12:26 PM   #2
Rewards Points: 1,713
Re: Lines in Cement
Crazing cracks like that are usually from the curing process... Concrete that dries out too quickly or unevenly can do that. It's why they suggest wetting or covering concrete for several days until it has has a chance to significantly cure. It's likely been there from day one.
Estranged likes this.
XSleeper is offline   Reply With Quote
Old 06-21-2020, 12:35 PM   #3
JUSTA MEMBER
Rewards Points: 3,774
Re: Lines in Cement
picture is not plain enough to see well.
What I see there is evidence of "dry troweling".
Where the let it dry a little, before finish troweling it , this creates a splotchy finish, and is supposed to mimic aging.
ED
de-nagorg is online now   Reply With Quote
Old 06-21-2020, 12:38 PM   #4
Estranged's Avatar
Rewards Points: 44
Re: Lines in Cement
ED
Hi De , thanks for your response, I just added another picture because yeah you're right i realize that one didn't really show much
Old 06-21-2020, 12:47 PM   #5
JUSTA MEMBER
Re: Lines in Cement
Now , I see, said the deaf mute to his son, as they walked down the road with their three legged dog.
Those are stress cracks, probably from drying too fast in the beginning.
If they widen, it needs replaced.
If they stay as is. Fugeddaboutit.
ED
Old 06-21-2020, 12:49 PM   #6
Estranged's Avatar
Rewards Points: 44
Re: Lines in Cement
ED
Thanks again, I'm hoping for the best it has been like that since they poured it last August with no new lines appearing just the ones originally from that time
Rob
Old 06-21-2020, 12:55 PM   #7
JUSTA MEMBER
Re: Lines in Cement
The surface dried first, due to the August heat, but the core still cured for days, thus causing a little stress on the surface.
Give it a couple of years, to see if it starts flaking and popping off.
Maybe it won't, maybe it will.
ED
The Following User Says Thank You to de-nagorg For This Useful Post:
Estranged (06-21-2020)
Old 06-21-2020, 12:59 PM   #8
Estranged's Avatar
Rewards Points: 44
Re: Lines in Cement
ED
Thanks Ed
de-nagorg likes this.
Old 06-21-2020, 07:29 PM   #9
Estranged's Avatar
Rewards Points: 44
Re: Lines in Cement
Hi X , from when I remember now is it has been there since day one I know I did wet it down as per the gentleman's instructions I just can't remember the details of how I did it and what I did
Rob
Old 06-21-2020, 07:37 PM   #10
retired framer
Rewards Points: 15,110
Re: Lines in Cement
I think I would seal it with the hopes of keeping water out of the cracks.
Mike Milam and Estranged like this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-22-2020, 12:02 AM   #11
Estranged's Avatar
Rewards Points: 44
Re: Lines in Cement
Hi Neal , I agree, I actually did seal it with a Thompson's Sealer last week I've given it 3 coats just because the seal seemed a bit watery after it was stirred so I don't know if that's the way it's supposed to be or not
it says do a water test afterwards then which I let it seal for 24 hours each coat and then put the water on it, it did roll off so it seems to be working.
I'm a put a few more seals on before the winter time I'm just wondering if anybody would recommend dry locking it or if that would be bad for it I'm not even sure if drylok will work now because it goes into the pores of the cement and with the sealer on it may defeat the purpose
Thank you
Old 06-22-2020, 01:24 AM   #12
retired framer
Re: Lines in Cement
Thank you
I would leave it as is now and check the seal every year.
figure 7-14
Old 06-22-2020, 09:52 AM   #13
Rewards Points: 4,132
Re: Lines in Cement
Seal it with real concrete sealer, Thompson’s is about as good as urinating on it.
de-nagorg and dj3 like this.
Old Thomas is offline   Reply With Quote
Old 06-24-2020, 04:22 PM   #14
Estranged's Avatar
Rewards Points: 44
Re: Lines in Cement
Originally Posted by Old Thomas View Post
Seal it with real concrete sealer, Thompsonís is about as good as urinating on it.
Thanks old T, never tried urination as a sealer, so you're one up on me there
Old 06-24-2020, 09:59 PM   #15
dj3
Rewards Points: 1,270
Re: Lines in Cement
Sealer in the sun?
Hope for the best, it could go for years, or not.
dj3 is online now   Reply With Quote
