How To Pour Concrete Into A Hole - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-24-2015, 02:45 AM   #1
Rewards Points: 22
how to pour concrete into a hole
Maybe the title of this thread doesn't do my question justice, but anyway...
I have a footing all formed and ready to have the local rockery bring me some concrete to pour. The problem is that the footing is 5'8" below ground. It's a footing for a retaining wall and has no way of me reaching it with a wheelbarrow, like by a ramp, or ground slope. Also, I don't think I can't simply pour the concrete by tilting the wheelbarrow from the surface 4'8" above because it might spill, and there are areas where the wheelbarrow won't make it.
So I guess my question is, is there like a concrete ramp I can rent/build that will allow me to slide the concrete from the wheelbarrow to the footing? I'd move it as one area got done and keep on going from there...
Also noticed that there are those big cement pump trucks. Are those typically more expensive to deliver vs the traditional cement truck? Or would I need both trucks (that sounds like it'd be really expensive)
tcabaco is offline   Reply With Quote
Old 03-24-2015, 05:56 AM   #2
Rewards Points: 3,272
Ready mix trucks and wheelbarrows shouldn't be mentioned in the same sentence. You need a pumper.
Old 03-24-2015, 10:29 AM   #3
Rewards Points: 1,016
Small stone pumper is less money than large stone, if your project can use small stone.
____________
Vince
Old 03-24-2015, 11:25 AM   #4
landfillwizard's Avatar
Rewards Points: 618
Many times a concrete company have conveyors that will place concrete without the use of a pump. Check to see if the concrete company has one!
landfillwizard is offline   Reply With Quote
Old 03-24-2015, 11:39 AM   #5
Super Moderator
joed's Avatar
Rewards Points: 30,184
You can build yourself a ramp out any material you might have laying around. A couple of 2x6 or 2x8 strapped together or plywood with 2x4 sides.
The Following User Says Thank You to joed For This Useful Post:
stadry (03-24-2015)
Old 03-24-2015, 04:58 PM   #6
Rewards Points: 2,744
trlr pumps are $750 for 1/2d here in atl,,, that's just the pump + the mix is different w/smaller rock in it,,, its a pita to move the 3" - 4" hose around a jobsite when its empty let alone when its full of conc front discharge trk may work for you or even a bobcat watch out for excavation sidewall cave-ins
no idea where your 'where' is but i'd sure wait for dry ground
Old 03-24-2015, 05:05 PM   #7
Rewards Points: 22
Thanks everyone, I think the way to go is pump... it's 7 yards worth of concrete, so it'll be well under the minimum 3h they do here in Northern California.. I'll basically end up paying 300%+ of what I should, but I guess that's what I need to do...
The Following User Says Thank You to tcabaco For This Useful Post:
concretemasonry (03-25-2015)
Old 03-24-2015, 06:42 PM   #8
Rewards Points: 1,042
And when it's all over, you'll wonder why you ever hesitated to do the placement the way you did, sure beats wheeling it.
Canarywood1 is offline   Reply With Quote
Old 03-25-2015, 12:00 AM   #9
Rewards Points: 5,002
Depending where you are....
https://www.google.com/search?q=conc...h=685#imgdii=_
ron45 is offline   Reply With Quote
Old 03-25-2015, 12:16 PM   #10
Originally Posted by ron45 View Post
So she puts the concrete in the hole for you?
____________
Vince
Old 03-25-2015, 12:40 PM   #11
Rewards Points: 22
That escalated quickly...
Pour concrete over sunken slab (floor)? ThomasC Building & Construction 23 04-05-2017 11:41 PM
Drain pipe hole where I want to put self leveling concrete Arsinek Remodeling 5 03-05-2014 11:43 AM
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
First time concrete pour cbzdel Concrete, Stone & Masonry 18 08-25-2013 04:19 PM
Concrete Footing Pour and Post Base Installation GuyJ Building & Construction 12 12-05-2011 10:42 AM
