How To: Concrete Ellipse - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By stadry
Old 06-01-2017, 01:38 AM   #1
Rewards Points: 12
I'm looking to create an elliptical concrete sculpture similar to the one in the link below. I'm just getting into working with concrete for sculptural elements so I wanted to lean on the collective knowledge of you all before completely botching this project.
Some of the questions I have:
- What's the best method and material to create an elliptical mold?
- How might I suspend the glass bits in an evenly distributed way?
- What brand of white concrete do you recommend for a structure such as this?
citydweller is offline   Reply With Quote
Old 06-01-2017, 01:50 AM   #2
Rewards Points: 12
Re: How To: Concrete Ellipse
Hmm, guess I'm too green to post links or images. I'll try to paint an image in your mind's eye... Picture an ellipse that's 24"(W)x18"(H)x12"(D). Thickness of the ellipse is approximately 1-1/2". Material is a white concrete with flecks of recycled glass.
Google "concrete exchange newbold bird feeder" if you'd like to see an image of the concept I'm referring to.
Old 06-01-2017, 07:39 AM   #3
Rewards Points: 2,742
i'm not aware of the various white cements however both cheng & buddy rhodes sell products to the public,,, 'cement-all' MAY be available at your local apron /vest store,,, you could also try sher-wms - they own d & c & have duo-top mtls avail
building the form ? get 2 cylinders - big deal
most here aren't into aesthetic conc,,, we're mostly belt & suspenders guys who don't wear berets & probably carry hawks more often than palettes
Bud9051 likes this.
Old 06-01-2017, 11:18 AM   #4
Rewards Points: 1,042
There is no brand of white concrete, but i think you mean a brand of white cement, which is available throughout the whole country, a mix design is usually worked up by a lab, and a mockup is constructed on site, before the actual job is a go.
Canarywood1 is offline   Reply With Quote
Old 06-01-2017, 12:29 PM   #5
Rewards Points: 44
You're talking about this:
If you google for articles on how to make concrete countertops you'll find information on how to produce different colors and finishes. How to mold the shape is an interesting problem. Lots of bathroom wastebaskets are oval. If you could find two of the right dimensions they might work. Otherwise, building a reusable form is going to be a bit more involved.
abrowning is offline   Reply With Quote
Old 06-01-2017, 12:37 PM   #6
Rewards Points: 44
That looks like a fragile feeder. I wonder if there's some kind of rigid core in it.
Old 06-01-2017, 05:40 PM   #7
should be strong enough for 10- 15 birds at a time,,, might think about adding a handful of fiber into the mix tho,,, never know when a squirrel'll hop aboard
there's too many pre-engineered mixes avail on the market,,, even countertop guys have mostly given up on formulating their own mix designs
Old 06-02-2017, 10:34 AM   #8
Rewards Points: 12
Great idea regarding the oval wastebaskets. Hadn't considered that. Now I need to just find two baskets of the same shape but different size that are perfectly upright. Or I suppose I could cut the bottom off one of them and ply it meet the shape of the other...thinking out loud.
The real challenge as I see it is in suspending the aggregate along the full face. If I use too thin of a mix, the aggregates will collect at the bottom. If I use a thick mix and paste the cement to the walls before pouring, I wonder if I can get a smooth, crack-free surface.
Are there any additives to the mixing process that will make the consistency of the cement into more of a spackle paste or putty?
Old 06-02-2017, 11:00 AM   #9
Rewards Points: 44
I was thinking that you would put them in normal wastebasket orientation for the pour and every so often tamp down the concrete with the largest dowel that would fit the space.
If you could bolt them together through the bases using bolts and washers that would keep them from moving as the concrete was poured.
I've never done anything like this before so my idea could be completely untenable, but at least it's an initial approach.
If you do cut the base off the inner one you might have to find a way to prevent it from flexing under the weight of the concrete. Maybe some oval plywood supports to jam in the middle. It might flex at the top even if it has a base.
Old 06-02-2017, 11:44 AM   #10
Super Moderator
joed's Avatar
Rewards Points: 30,158
Not sure trash can are the best idea but if you want go that rout then leave the bottom. screw the inner can bottom to the outer can bottom to hold it in place.
Old 06-02-2017, 01:00 PM   #11
Rewards Points: 44
Smooth sided wastebaskets are a shortcut that may or may not work. What's the alternative? An elliptical wooden core and a silicone mold, maybe? I've never done anything like that but it's probably a piece of cake if you have the skills. I could make the elliptical core.
Old 06-02-2017, 08:52 PM   #12
sheet of formica like the conc c-top folks use
Old 06-02-2017, 09:18 PM   #13
Rewards Points: 3,248
Cut sizes of PVC pipe to length , heat and press them into an ellipse to form the mold with one inside to give desired wall thickness.
Framing for Room half over old Concrete porch posulli Building & Construction 2 11-17-2016 03:43 PM
New Concrete Over Old Concrete Pier succeed Concrete, Stone & Masonry 1 09-05-2016 04:05 PM
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 05:10 AM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
