How To Best Match Stucco Exterior - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-08-2015, 12:22 PM   #16
Rewards Points: 2,700
looked at that earlier,,, like it ? good for patchwork ?
Old 11-08-2015, 12:38 PM   #17
Rewards Points: 58
Originally Posted by stuart45 View Post
I've got a cheap flicker gun from Silverline that produces a heavy finish(even thicker that), when it first comes out of the gun.
I just looked at my texture job this morning and its just flaking off when you touch it. Did I not wet it enough or was the stucco beneath not accepting that finish stucco? Does it harden more over time?
saxsquad29 is offline   Reply With Quote
Old 11-08-2015, 12:49 PM   #18
Rewards Points: 582
I've found it good for patchwork once you get used to it. Probably best to do a fair bit of practice first.
Best to get the base coat almost level with the finish and let it get bone dry, as if it's a bit damp the Tyrolean coat tends to run a bit.
The bigger blobs tend to come out first.
It's only a cheap gun and you can pay a lot more for one, but I only do patches as it's normally the plasterers job here.
stuart45 is offline   Reply With Quote
Old 11-08-2015, 12:51 PM   #19
Rewards Points: 582
What mix did you use. It normally sticks once it been on for a while. it should harden up in time. You might have put it on a bit thick.
Old 11-08-2015, 01:19 PM   #20
Rewards Points: 58
I used the quickrete finish stucco
Its been on for 24hrs. Should I have wet it as it was curing?
Old 11-08-2015, 01:40 PM   #21
Rewards Points: 582
Shouldn't need to wet it. There is a Tyrolean mix you can get, but I usually mix my own with sand/cement.
painting/prepping stucco exterior of old school oldschoolamy Painting 0 07-31-2015 09:39 PM
Pulled coaxial cable from exterior stucco wall - how to plug hole? JonDIY Insulation 2 04-11-2013 01:57 PM
Looking for exterior finishing ideas for 1920's craftsman stucco home Keeney Building & Construction 10 02-06-2013 09:19 AM
Best color for stucco second floor part of office building exterior FrankL Painting 3 04-11-2012 07:25 AM
replacement windows with stucco exterior willie hazel Building & Construction 0 10-12-2010 05:10 PM
