How To Best Match Stucco Exterior - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-04-2015, 01:26 PM   #1
Rewards Points: 58
How to best match stucco exterior
I am patching some areas on my exterior stucco home and am trying to match the existing heavy dash texture. Any helpful hints on getting the right consistency for the finish coat. Pic of texture attached. I bought a bag of finish coat stucco and masonry sand.
saxsquad29 is offline   Reply With Quote
Old 11-04-2015, 02:51 PM   #2
Rewards Points: 1,232
Mix it to slightly loose peanut butter consistancy, then dip a straw whisk broom into the mix, run your fingers along the straw below the mortar, "shooting" the stucco onto the wall.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-04-2015, 03:57 PM   #3
Rewards Points: 58
Should I use any other aggregate other than sand, like pea gravel, etc
Old 11-04-2015, 08:15 PM   #4
No, the finish coat should have the correct aggregate in the bag.
Old 11-05-2015, 08:45 AM   #5
Rewards Points: 582
http://www.wonkeedonkeetools.co.uk/m...ating-sprayer/
Using a Tyrolean gun can take a bit of practice to get a good match.
stuart45 is offline   Reply With Quote
Old 11-05-2015, 10:29 AM   #6
Rewards Points: 58
I have a masonry brush that might work or do I need an actual dash stucco brush
Old 11-05-2015, 11:24 AM   #7
Rewards Points: 582
Test it out somewhere first as it takes a bit of time to get the right mix and method right. Getting too heavy a finish seems to show up more than too light a finish.
The wetter you make the mix the lighter the finish.
Old 11-05-2015, 11:25 AM   #8
It needs to have very stiff and long bristles.
Old 11-07-2015, 06:35 PM   #9
Rewards Points: 58
I made up some finish stucco(quickrete) and made it thick enough but I could not achieve that thick "snot" texture that I have. When I flung it with the brush it had more if a flat texture. I'm after more thick more protruding "blobs". Was it maybe my brush that wasn't stiff enough or do I need the mix even thicker?
Old 11-08-2015, 09:56 AM   #10
Rewards Points: 2,700
stuart, do you use these ? http://www.ebay.com/itm/121687722845...845%26_rdc%3D1
stadry is online now   Reply With Quote
Old 11-08-2015, 11:04 AM   #11
Rewards Points: 582
I have used them on bigger re-pointing jobs. Seems you can buy them cheaper than us, even though it's posted from Manchester. Must be you don't pay our VAT (value added tax) at 20%.
Old 11-08-2015, 11:26 AM   #12
Rewards Points: 58
Do you guys have any advice on my last post- couldn't achieve that thick snot like texture
Old 11-08-2015, 11:57 AM   #13
we don't now but give the basta*** enough time & we will here too
Old 11-08-2015, 12:11 PM   #14
Rewards Points: 582
I've got a cheap flicker gun from Silverline that produces a heavy finish(even thicker that), when it first comes out of the gun.
Old 11-08-2015, 12:16 PM   #15
Rewards Points: 582
http://www.toolandfix.com/silverline...FWjmwgod1PIExw
painting/prepping stucco exterior of old school oldschoolamy Painting 0 07-31-2015 09:39 PM
Pulled coaxial cable from exterior stucco wall - how to plug hole? JonDIY Insulation 2 04-11-2013 01:57 PM
Looking for exterior finishing ideas for 1920's craftsman stucco home Keeney Building & Construction 10 02-06-2013 09:19 AM
Best color for stucco second floor part of office building exterior FrankL Painting 3 04-11-2012 07:25 AM
replacement windows with stucco exterior willie hazel Building & Construction 0 10-12-2010 05:10 PM
