Help With Edging Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree10Likes
  • 5 Post By Canarywood1
  • 1 Post By Shopguy
  • 1 Post By de-nagorg
  • 1 Post By joed
  • 1 Post By MTN REMODEL LLC
  • 1 Post By jomama45
Old 06-10-2017, 07:05 PM   #1
Rewards Points: 132
Help with edging concrete
I'm going to be pouring some concrete into some 20 inch diameter sonotubes that extend above the ground a couple of feet.
I would like to round off the outside edge at the top of the sonotube so they look nice and are resistant to chipping.
I've tried doing this before with rounded edges and it never seems to work.
Is there a trick or tool for this besides a standard edger? My edger looks like this:
http://www.homedepot.com/p/Marshallt...3-HD/202091765
I've tried tipping it up on an angle but that seems to dip the bottom edge into the concrete and the finish is ugly.
Shopguy is offline   Reply With Quote
Old 06-10-2017, 07:36 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 866
Re: Help with edging concrete
Since your edge may not be exposed above the sonotube while it is wet, it may be difficult to use the normal edging tool. You could use a mortar joint strike took or fashion one by cutting a 3/4" piece of PVC or conduit in half lengthwise and running the tip of it around the edge while wet. Otherwise, you could just grind it round after it cures out with an angle grinder.
chandler48 is online now   Reply With Quote
Old 06-10-2017, 07:52 PM   #3
Rewards Points: 7,784
They stamp concrete in unique patterns for driveways or patios. You could make a circle with the bevel around the edge and before the concrete sets you place it on top, inside the tube, and tap down to form your nice edge. You could even get creative with something fancier than a simple rounded edge.
Bud
Bud9051 is offline   Reply With Quote
Old 06-10-2017, 07:56 PM   #4
Rewards Points: 1,042
The trick is to get the right tool for the job, here's a link.
http://www.lewiscontractorsales.com/...m8qhoCWB3w_wcB
Canarywood1 is offline   Reply With Quote
The Following 2 Users Say Thank You to Canarywood1 For This Useful Post:
MTN REMODEL LLC (06-10-2017), Shopguy (06-11-2017)
Old 06-11-2017, 01:15 PM   #5
Rewards Points: 132
Wow.. talk about the right tool for the job!
The only problem I see is that they don't make a 20 inch diameter model.. Should I get the larger one or the smaller one? And why?
My first thought is to get the larger one and just lift it up a bit on one side. Seems to me that a larger radius can always be made smaller by a slight angular adjustment, but a smaller radius can not be made larger.
MTN REMODEL LLC likes this.
Old 06-11-2017, 01:29 PM   #6
JUSTA MEMBER
Rewards Points: 1,124
I'm betting that you can fashion something like that on your own, by finding a pie / cake tin just the right size at a garage sale, flea market, second hand store.
And cutting the tin in half, adding a drawer handle, and using that to round over the edges of your piers.
ED
de-nagorg is offline   Reply With Quote
Old 06-11-2017, 01:29 PM   #7
Super Moderator
joed's Avatar
Rewards Points: 30,164
Since this is probably the only time you will use I would try a fashion something out of a block of wood and some tin.
Old 06-11-2017, 02:52 PM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 528
ED
And if you find a 20" pizza pan.... you'll have your radious right on...
de-nagorg likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 06-13-2017, 12:05 AM   #9
Rewards Points: 92
Hey please check video.........
Hope it would be helpful to you.
creativeconcret is offline   Reply With Quote
Old 06-13-2017, 01:41 PM   #10
Oso954's Avatar
Rewards Points: 690
I'd change my pier/sonotube to 18 or 24 inch, and buy the tool that is made for the job.
Oso954 is online now   Reply With Quote
Old 06-13-2017, 05:57 PM   #11
Concrete & Masonry
Rewards Points: 458
The edger that the OP linked to is a POS, which is likely why they've never had any success using it. You need something wider, and preferably short in length for a tight radius. We have a wide array of different edgers, I'd likely use a 6"x 2" edger for 20" sono tubes. Plan on edging it 2-3 times to get it looking the best, and don't try to edge it too early, as you'll just displace a lot of the stones.
http://www.bontool.com/product1.asp?P=RADIUSEDGER
jomama45 is offline   Reply With Quote
New Concrete Over Old Concrete Pier succeed Concrete, Stone & Masonry 1 09-05-2016 04:05 PM
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 05:10 AM
Concrete and Brick Repairs spidercharm Building & Construction 6 08-26-2012 05:15 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
