Help With Concrete Fireplace - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By jomama45
Old 02-15-2019, 07:47 PM
Rewards Points: 2
Help with Concrete fireplace
I have framed out a fireplace with durock. What is the best product and method to use to get a smooth glossy finish? I know some sanding will be necessary. I was considering spraying GFRC but unsure if it will run too much on the vertical surface. Thank you for your advice!!
bailydog is offline
Old 02-15-2019, 09:14 PM
Rewards Points: 88
Re: Help with Concrete fireplace
Use a Venetian Plaster NO SANDING required.
ClarenceBauer is online now
Old 02-15-2019, 11:32 PM
Concrete & Masonry
Rewards Points: 422
I've cast my share of GFRC precast with a buddy of mine who did concrete countertops/etc... The problem is that you can't actually spray GFRC, as far as I know. You can spray a face coat w/o the fibers, but that's kind of against the point, as it's not GFRC.
Not sure how you're going to get GFRC flat and smooth on a vertical surface without casting it flat and tipping it into place after it cures.
stadry likes this.
jomama45 is offline
Old 02-16-2019, 08:44 AM
Rewards Points: 88
With the right equipment you can spray GFRC but foe a one time fire place it would be very high $$$$. Tape the board joints as per manufactures recommendations than apply a very thin base coat of a veneer plaster & than finish with a smooth troweled finish coat it should be a smooth as glass if you use the right material.
New Concrete Over Old Concrete Pier succeed Concrete, Stone & Masonry 1 09-05-2016 04:05 PM
Patching subfloor from fireplace removal eastie Building & Construction 1 11-12-2015 03:10 PM
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 10:03 AM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
