Grading Question - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-25-2019, 02:29 PM   #1
Rewards Points: 22
Grading Question
I need to do some grading work around my newly purchased home this spring.
I understand the code to require:
- 8 from non treated wood (structure, sheathing, siding) to ground
- 6 from treated wood to ground
- 2 from either treated or non-treated wood to properly sloped impervious surface like concrete
- Lots shall be graded to drain surface water away from foundation walls. The grade shall fall a minimum of 6 inches (152 mm)within the first 10 feet (3048 mm)
Do I have this right?
mpls69 is online now   Reply With Quote
Old 02-25-2019, 02:33 PM   #2
retired framer
Rewards Points: 1,476
Re: Grading Question
That sounds really good.
Do not use flat bottom gables with scissor trusses.
Grading Question sbkim Landscaping & Lawn Care 5 07-01-2014 01:10 PM
grading dirt in backyard question Pawl Landscaping & Lawn Care 6 06-01-2013 11:01 AM
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 09:11 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
