Gap Between Garage Pad And Asphalt Driveway - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By Bondo
Old 04-04-2019, 11:14 AM   #1
Rewards Points: 1,750
Gap between garage pad and asphalt driveway
16 year old concrete driveway pad and asphalt driveway. I imagine the driveway has settled/moved somewhat, and flexed away from the edge of the slab. What's the correct way to minimize water intrusion into the subgrade below both? I was thinking to use the foam rope and caulk method that's used for sealing swimming pool edges.
huesmann is offline   Reply With Quote
Old 04-04-2019, 04:25 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,792
Re: Gap between garage pad and asphalt driveway
Is the driveway sloped into the garage? If not, I wouldn't worry about the water. If it is, the water is probably still getting into the soil formation.
The issue I see is that nothing ever quite holds up in those cases and almost universally pulls away...at which point...it looks worse than the gap.
Bondo likes this.
Old 04-04-2019, 04:31 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,918
Ayuh,..... 99.9% of the driveways I over-lay look exactly like that,.....
Which is Great for me, as I don't have to cut out a big strip across the garage to make "Space" for the over-lay,....
Like WoW, I wouldn't give it a 2nd thought,.....
Windows on Wash likes this.
Old 04-05-2019, 09:41 AM   #4
No, the driveway more or less drains away (has a couple little dips where water sits). And obviously there's no runoff coming from the garage itself. However, we do get a fairly significant amount of rain onto the garage door when it rains (guess it's just the wind patterns around the house), and that's what my concern is, because the rain on the door drips down, and into the gap.
Old 04-07-2019, 03:54 AM   #5
Rewards Points: 2,700
stay inside or look the other way,,, IF you'e want to get serious, buy closed cell backer rod ( NOT yellow denver foam ) & find some dow-corning 890 silicone which adheres to both conc AND asphalt,,, install 1/4" below top surface & NO MORE than 3/8" thick - http://www.ssicm.com/assets/pdfs/DC_890.pdf
