Fixing Foundation Bricks - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree5Likes
  • 2 Post By Windows on Wash
  • 2 Post By Nealtw
  • 1 Post By stadry
Old 12-02-2019, 12:55 PM   #1
Rewards Points: 34
Fixing foundation bricks
Hi,
How should I go about fixing this?
Should I use mortar mix cement to fill in the cracks or use some sort of silicone sealant?
Thank you!
michaeldrehl is offline   Reply With Quote
Old 12-02-2019, 01:38 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,542
Re: Fixing foundation bricks
How old are the cracks and what are they from.
Re-pointing would be indicated here but you need to first figure out what caused the movement.
joecaption and stuart44 like this.
Old 12-02-2019, 02:25 PM   #3
Rewards Points: 34
I have no idea how they formed or when they formed. Just noticed this about a month ago. The house is about 125 years old.
This is the only crack I see from the outside of the house.
Old 12-02-2019, 02:28 PM   #4
Super Moderator
Gymschu's Avatar
Rewards Points: 132
Yup, grind out the joints and repoint. You lucked out in that the bricks themselves did not crack, or at least it appears they did not form cracks.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 12-02-2019, 02:47 PM   #5
retired framer
Rewards Points: 1,244
You may want to check the mortar type on an old wall.
bob22 and Windows on Wash like this.
Do not use flat bottom gables with scissor trusses.
Old 12-02-2019, 03:48 PM   #6
Rewards Points: 2,568
125 yrs old & that's the limit of damage ? we'd repoint w/soft-mortar - wait a bit then paint to match existing
Windows on Wash likes this.
Old Yesterday, 12:38 PM   #7
Rewards Points: 132
That's an important point. There may be a leaking drain at the bottom of that downpipe, which I have found often causes movement in the brickwork.
stuart44 is offline   Reply With Quote
