First Time Foaming Basement Cement - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree3Likes
Old 01-20-2017, 09:05 AM   #16
Civil Engineer
Rewards Points: 5,246
Re: first time foaming basement cement
There is a pretty good article on foamcrete in Wikipedia, see https://en.wikipedia.org/wiki/Foam_concrete.
This is a real product with a variety of applications, however house construction is not a typical use for foamcrete.
Old 01-20-2017, 10:07 AM   #17
Rewards Points: 1,042
Originally Posted by concretemasonry View Post
The use of "foam" in the concrete mix has been very feeble/limited in the U.S.with the exception of precast sandwich panels. These are a plant process and do not involve contractors on site.
Conventional shape block with better insulation have been made in a limited way in the U.S., but only in a plant where there is better controls of the conditions and materials. The most common method is to use lighter weight aggregates - manufactured expanded aggregates or natural light aggregates (scoria, pumice).
I was involved in the manufacture of conventional shape concrete block made from expanded polystyrene beads mixed with manufactured and/or normal aggregates. In order for it to work, the heavier aggregate must be finer than normal to be mixed uniformly and a wetting chemical (wetting agent) must be used to permit the cement matrix to bond to the lightweight expanded foam beads. We were able to make loadbearing 8" block in a block plant that weighed less than 18#(they went into my lake home) that the masons loved. There is no way a contractor can get the control and uniformity of real lightweight construction on a job site.
The "crumbled"/shredded waste foam boards with variable properties are good for nothing except poor construction with no controls.
Dick
Your post makes sense to me, i doubt any concrete producer in the USA would be involved with something like that, as it would involve dedicating a plant to the sole production of that item, and that i doubt would happen.
I'll bet your masons were happy, with the light weight blocks being 18 lbs. as opposed to the standard 28 lbs.
Canarywood1 is offline   Reply With Quote
Old 01-20-2017, 10:47 AM   #18
concretemasonry's Avatar
Rewards Points: 2,716
I am familiar with the performance or as some people say "insulation value". Many people in the U.S. are not aware of the benefits of "thermal inertia" that is a real proven money saver. Unfortunately, it is easier for domestic product/material suppliers to market the fallacious "R-value" that can be totally misleading.
If you ever sit on a code or standards that tries to write an enforceable code or materials standard it is like facing the opponent with an unlimited checkbook and an unlimited number of employees.
Dick
concretemasonry is offline   Reply With Quote
Old 01-20-2017, 10:50 AM   #19
Rewards Points: 2,704
http://www.litebuilt.com/lightweight...-handbook.html = what daniel posted,,, i'm not aware of any large (or even small) use yet today here in the usa
Old 01-20-2017, 02:20 PM   #20
And i doubt you will see it in the foreseeable future, of all the schools and seminars i've attended over the years, it was never even mentioned, you would also have to dedicate a central mix plant to avoid contamination with standard concrete, that alone would send the cost sky high.
Old 01-21-2017, 07:42 AM   #21
by now the op must be holdin' his head in his hands wonderin' ' why did i ever ask ? ' we may have scared him off
Msradell likes this.
Old 01-21-2017, 06:38 PM   #22
More than likely it's about ICF's
leveling cement basement floor for tiling? Braddiy Flooring 5 03-17-2013 12:20 PM
Basement Cement Block Wall Movement Iowa_Mike Concrete, Stone & Masonry 13 01-04-2013 09:01 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 06:06 PM
