Finding The Source Of Moisture - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-19-2019, 12:24 AM   #1
Rewards Points: 40
Finding the Source of Moisture
I got the moisture meter thing and it reads 25-30 in the exposed area next to the bathroom. No other wall, exposed or not, ceiling bubbling or not, reads nearly that high. Areas closer to the edge are less, I don't know how high it goes. There is some exposed stuff I dont understand. How do I find the source? What could it be? It isn't lower like the carpet and wouldn't a roof leak leave a stain? Old plumbing?Finding the Source of Moisture-img_20190407_231503-1-.jpg
dcultravillain is offline   Reply With Quote
Old 04-19-2019, 12:25 AM   #2
Rewards Points: 40
Re: Finding the Source of Moisture
Sorry hose are the older pics ill have to charge my phone
Old 04-19-2019, 03:56 AM   #3
Rewards Points: 4,370
With the little information you've given us, it could be anything. Time to start looking for patterns - is there moisture when it rains? When someone showers? When someone flushes? All the time?
Best is to make a hole so you can poke your head up there and look around. Keep in mind water can travel quite a ways horizontally.
stick\shift is offline   Reply With Quote
Old 04-19-2019, 11:36 AM   #4
Rewards Points: 40
I know it's not a lot because I just only reccently knew the carpets were damp. There was one time I used the tub a lot and it DID get his carpet on the other side wet. I haven't noticed if it got worse during the rain. There seemed to be no corrrelation. there is a drainage leak in the tub. ill take a pic
Old 04-19-2019, 02:02 PM   #5
retired painter
Rewards Points: 1,378
Repairing known leaks is a good place to start!
mark sr is offline   Reply With Quote
HELP! Slab on grade 95 % moisture dkwetslab Building & Construction 12 11-27-2015 12:31 AM
basement tile - moisture - porcelain - ditra question anamika Tiling, ceramics, marble 3 04-16-2014 10:17 PM
Moisture coming from attic. Heathcote Insulation 4 11-21-2013 12:46 AM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
