Fill Sunken Tub Hole, With What? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-14-2014, 02:50 PM   #1
Rewards Points: 18
Fill sunken tub hole, with what?
We have a sunken tub that we never use and I plan to put a shower in its place.
The hole the tub sits into was formed into the poured on grade slab.
I don't want to fill the hole with solid concrete in case I or someone else wants to open it back up for some reason.
Is there a product that I could use, that will give me the solid baseI need for a shower, but could be relatively easily sledge hammered out?
leojr is offline   Reply With Quote
Old 10-14-2014, 06:52 PM   #2
Rewards Points: 2,456
compacted granular base material, vapor barrier, & new conc
Old 10-14-2014, 07:37 PM   #3
Rewards Points: 18
Like a road base or similar? Thanks.
Is hand tamping be sufficient?
What is the vapor barrier for? The sunken hole is all concrete already. Well, except for the dirt cat box for the plumbing. Makes sense then.
Old 10-14-2014, 07:42 PM   #4
Rewards Points: 17,940
Waste of time trying to do this so it can be removed later.
No picture posted so my answer is based on logic.
Why would anyone want a sunken tub. Really want to have to get on your hands and knees to get in?
Old 10-15-2014, 05:28 AM   #5
you never said the hole was conc-lined, sport,,, ok - delete vapor barrier,,, walking on it's better than using your hands
joe, he wants a shower ( probably a stand-UP shower, too ) already HAS a sunken tub,,, think plumbing stuff should be moved 1st - would be IF it were in our house
Old 10-15-2014, 07:48 AM   #6
Rewards Points: 18
Thanks guys! I'm new to the forum and appreciate your patience.
Yes, it is an all concrete sunken rectangle that the tub sets into. There is the small area left uncovered with concrete for the drain to come up through.
After I raise the pluming and I think I'll still put some vapor barrier around that exposes dirt.
By "hand tamp" I meant that I would use a flat square metal casting that has a wooden handle. A person lifts it and lets it fall, compacting the material under it. If this hand tamping is not sufficient I would rent a vibrator from home depot or similar.
Too funny about just using my hands! But that is what I said...
Stepping down into a wet tub is a bit scary. Stepping up onto the floor with wet feet can be risky. And for an element of danger, on the big wall along the long side of the tub is a huge (5x7?) mirror. Non-tempered glass. As if the twisted or broken ankle isn't bad enough, the pieces of glass could be deadly.
Yes, turning this into a stand up shower. And you are right joecaption, I'm not going to spend too much more time trying to make this removable.
Thanks again for your help.
This isn't my first rodeo, but I'm often mistaken for a clown!
Dirt Fill Needed! bluewolf Landscaping & Lawn Care 4 03-16-2014 09:34 PM
raise sunken living room with fireplace jamxi Flooring 12 06-05-2011 04:33 PM
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 05:55 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
What to Fill Hole in the Trim With? limitdiy Carpentry 2 01-03-2010 09:20 PM
