Fill In Cores? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
Old 04-28-2019, 09:38 PM   #16
Concrete & Masonry
Rewards Points: 228
Re: Fill in cores?
Originally Posted by Canarywood1 View Post
Those are not on their side , and 3 core cmu's haven't been made for quite some time, 2 core are the dominant block and have been for some time, although they might be available as a special order, there's a contractor on this forum go's by jomama45 that would probably be able to tell you when the 3 core were last used.
I'm sure it's terratorial, but in these parts, by the late 50's/early 60's most block seem to have been 2 holers. Looking at the original picture, I think the cores are capped off, it's the handholds that remain open. It wouldn't hurt to stuff something rigid in them and cap the top inch or so with mortar.
jomama45 is online now   Reply With Quote
Old 04-29-2019, 12:46 PM   #17
Rewards Points: 2,314
Re: Fill in cores?
Jomama,
You are right; i looked at another pic I had on my and it does seem to be the handholds as you call them.
I guess mortar mix is good enough for this?
bob22 is online now   Reply With Quote
Old 05-02-2019, 02:55 PM   #18
Rewards Points: 108
Re: Fill in cores?
It looks like moisture is wicking up the wall above the cinder blocks. Is that drywall and is it all the down touching the cinder block? I would also be concerned about mold and mildew on the drywall and rotting of the sill plate. The sill plate of the wall should be pressure treated and/or have a sill gasket.
Hidyi is offline   Reply With Quote
Old 05-02-2019, 04:05 PM   #19
Re: Fill in cores?
Agreed.
That wall separates a walkway flower/shrub bed and I think it is too high with dirt/mulch that stays wet and moisture transits through the brick to the block etc....
I told my son what you essentially said; he best remove years of the accumulation so the wall doesn't rot out more than it may be already.
Nealtw likes this.
toilet takes to long to fill lonewolf22 Plumbing 5 11-30-2011 07:03 AM
toilet fill valve? Roundeye Plumbing 11 07-26-2011 01:17 PM
Leaking Fill valve tallman Plumbing 1 07-14-2011 01:01 PM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 09:37 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
