Expansion Joint? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-25-2014, 11:17 AM   #1
Rewards Points: 109
expansion joint?
I have a concrete pad that mt front stairs come down onto. The asphalt driveway butts up to this concrete pad. When it heaves in the winter it crumbles the asphalt. Should there be an expansion joint between the 2 different materials?
hitmehhh is offline   Reply With Quote
Old 03-25-2014, 11:35 AM   #2
Rewards Points: 18,808
Simple answer is yes there should have been.
Old 03-25-2014, 12:47 PM   #3
Rewards Points: 144
Easy enough job to cut the asphalt out 1/2 or so between the two.
mako1 is offline   Reply With Quote
Old 03-25-2014, 05:22 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,056
Ayuh,.... In the 22 years I've been buildin' roads, parkin' lots, 'n driveways,...
I've Always paved tight to the concrete,...
It's a natural joint which can heave independently of each other,...
If the blacktop is crumblin',...
My 1st question is How Old is the blacktop,...
Post a picture of it,...
Sounds like poor drainage of either the driveway, or the walkway,...
The Following 3 Users Say Thank You to Bondo For This Useful Post:
jomama45 (03-25-2014), Nailbags (03-26-2014)
Old 03-25-2014, 09:30 PM   #5
Concrete & Masonry
Rewards Points: 506
I've been pouring concrete for a similar amount of time, and I can't say I've ever seen expansion material placed between the two either, nor have I seen a detail that called for it. If the two materials are bearing on the same soil, there's not much reason they should move much differently...........
jomama45 is offline   Reply With Quote
Old 03-26-2014, 08:15 PM   #6
Rewards Points: 468
I wonder if the concrete pad is set below the frost line and the asphalt is floating.
My concrete walks and paths have taken a worse beating this winter than in the 18 years previous that I have lived in my house.
Jim F is offline   Reply With Quote
Old 03-28-2014, 01:46 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Make sure that the two can travel independently. If you've bonded the asphalt to the concrete with a sealant, the asphalt is going to crumble during a freeze thaw cycle from vertical movement rather than expansion/contraction.
Old 03-31-2014, 05:44 AM   #8
Rewards Points: 3,454
IF the right ' sealant ' has been used, there would have been a constructed joint but its unlikely in residential const - even expansion jnt mtl's not often used,,, in any event, there won't be any bonding,,, any likely crumbling will be due to inadequately compacted blacktop im-n-s-h-fo
Recurring ceiling crack - Drywall Expansion Joint? kuj0317 Drywall & Plaster 5 11-25-2012 11:27 PM
Concrete Driveway and expansion joint segal Concrete, Stone & Masonry 14 08-30-2012 09:25 AM
Goofy expansion joint question 614Brewer Landscaping & Lawn Care 2 06-09-2012 08:32 AM
Expansion joint john4153 Plumbing 0 10-05-2011 07:51 PM
Tiling over expansion joint - confused jkr77 Flooring 20 04-12-2011 03:56 PM
