Enlarging A Hole In A Concrete Planter - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By Bondo
Old 04-28-2019, 06:57 PM   #1
Rewards Points: 1,052
Enlarging a hole in a concrete planter
I need to put out a mooring for my "new" sailboat. I am told that 100 pounds should be adequate. I was going to fill a plastic drum with a couple bags of cement, but then I thought of these two concrete planters we have, but my wife hates. They weigh 73 pounds each, so two ought to be more than adequate.
The drainage hole is 1" and my chain requires 1.5". The bottoms are 1" thick.
Can I drill some holes next to the drainage hole and chip off the material between the holes to increase the size, or will that somehow destroy the integrity.
Obviously I don't know what I am doing, so any advice would be appreciated.
Toller is offline   Reply With Quote
Old 04-28-2019, 07:08 PM   #2
retired framer
Rewards Points: 4,470
Re: Enlarging a hole in a concrete planter
Just use eye bolts and nuts and big washers
https://www.siddhgiritubes.com/stain...s-manufacturer
Do not use flat bottom gables with scissor trusses.
Old 04-28-2019, 07:23 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,924
Ayuh,..... How ever you attach the chain, leave 5' or 6' of chain between 'em,.....
That way the wind/ boat has to lift the 1st one, before the 2nd one can move,.....
I used a 351 Ford motor as the base weight for my houseboat mooring, then 5' of chain, to an ole 4 cylinder motor, then more chain to the 20' mooring line to the houseboat,.....
It ain't moved in the 10 plus years it's been there,....
Nealtw likes this.
Bondo is online now   Reply With Quote
Old 04-28-2019, 07:28 PM   #4
retired framer
A friend asked all his friends for their weights sets that nobody uses a year later.
Patch Hole in Concrete Wall electronicsfrea Concrete, Stone & Masonry 3 02-27-2017 04:17 AM
drill 2.5" hole through 10" concrete hole diy001 Remodeling 7 01-17-2016 06:50 PM
Enlarging a room: Floor is poured concrete with different floor elevations. jedblack Building & Construction 7 09-09-2015 09:44 PM
how to pour concrete into a hole tcabaco Concrete, Stone & Masonry 10 03-25-2015 12:40 PM
I need to make a waterproof hole - can I use concrete? tibberous Building & Construction 7 12-18-2011 09:29 PM
