Durock Edges On Outdoor Kitchen - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-09-2017, 02:22 PM   #1
Rewards Points: 125
Durock Edges on Outdoor Kitchen
I'm building an outdoor kitchen. The framing is done and I'm hanging durock backerboard to put tile over. I plan to use the tile you see sometimes on modern fireplaces without grout. My questions is do I need to do anything to the cut edges of the durock? For example I'm installing a stainless steel cabinet door, so I'm cutting a hole in one of the pieces of durock for this to go into. Does anything need to be done to that cut edge of backerboard to seal it? Same question along the top where it will meet the concrete counter I plan to add later.
Second issue, one of the outside corners will have the stainless steel door cover all the way over the framing, but not enough to cover all the backerboard and thickness of tile. How is that edge typically finished?
Thanks,
Richard
rjschwar is offline   Reply With Quote
Old 06-09-2017, 07:42 PM   #2
Rewards Points: 18,194
Re: Durock Edges on Outdoor Kitchen
Where's the pictures so we can see what your seeing?
Old 06-09-2017, 08:33 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 518
If you wanted.... you could glue on some J channel.... comes in metal or white plastic.
MTN REMODEL LLC is online now   Reply With Quote
Old 06-09-2017, 09:39 PM   #4
Rewards Points: 125
I did buy some J channel for the corner while I was at my local big box today so the corner issues is taken care of. I haven't hung the backerboard so I don't yet have any pictures.
My concern is I know I need to tape and thinset the seams and I'm not sure if that is just to protect whatever is behind said seam, or if it also protects the cut edge of the backerboard. The first question was more durability than looks wise. If there is some exposed cut edge of durock that can't be seen but isn't sealed or waterproofed in any way will this be an issue, or is this typical?
Thanks,
Richard
Old 06-09-2017, 09:47 PM   #5
Rewards Points: 518
You tape durok to mitigate water transmision to whatever is underneath... not to protect its edge.
Also to a limited degree to give a solid plane for your tile to set.
Is your framing wood or metal stud and is it likely to be exposed to much rain / moisture intrusion.
I guess regardless of the circumstances, I'd tape it. Relatively no cost and maybe 1/2 hour for a barbecue pit.
Good goin..
Old 06-10-2017, 07:27 AM   #6
Naildriver
chandler48's Avatar
Rewards Points: 582
You may find the drywall corner j channel will fit perfectly. Not sure whether the j channel you bought was for drywall or for vinyl siding, but these seem to work great on exposed edges of 1/2" material. http://www.homedepot.com/p/Phillips-...YL-8/203116180
chandler48 is online now   Reply With Quote
Old 06-11-2017, 01:41 AM   #7
Rewards Points: 125
Great thanks for the help.
Richard
Durock boilermaker27 Building & Construction 2 02-23-2014 11:17 PM
Sand down edges of drywall patch panel for tape? patchtaper Drywall & Plaster 2 12-15-2012 10:53 PM
Seal durock to cast iron shower receptor? rightit Tiling, ceramics, marble 2 12-08-2012 05:44 PM
Fixing my Durock Mistake ScubaGeekNC Flooring 12 05-24-2012 08:48 PM
Liner and Durock placement rightit Kitchen & Bath Remodeling 7 03-13-2012 07:35 AM
