Dealing With Water Intrusion(Basement) - Concrete, Stone & Masonry - Page 4 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree8Likes
Old 03-25-2020, 12:47 PM   #46
Rewards Points: 32
Re: Dealing with water intrusion(Basement)
Guess everything is relative at that...there are thousands (if not tens of thousands) of homeowners that wish their sump pump only ran every fifteen minutes!! Mine will cycle every minute under worst conditions. Guess that's why I have a primary pump, a secondary pump, and two backup generators. Full alarm system also (for high water level in sump and also for water on floor in basket vicinity) Count your blessings!
Sparky911 is offline   Reply With Quote
Old 03-25-2020, 01:07 PM   #47
Rewards Points: 172
The only way to fix this is install a proper foundation drain (outside your foundation) to divert water around your house. Anything else and you will be fighting water intrusion and flooding until you install a proper foundation drain. I'm surprised you were able to construct new construction without a foundation drain, it's typically required by UBC and all new construction. If they did install a foundation drain, they did something wrong, perhaps not connecting to your existing foundation drain. Not only do you risk water intrusion, but you risk foundation settlement due to water undermining the soil under your foundation.
Tom153 is offline   Reply With Quote
Old 03-25-2020, 01:08 PM   #48
Rewards Points: 346
Originally Posted by Nealtw View Post
I don't think I'd be convinced of much by that video. It's basically just an advertisement saying how great his product is. He keeps going on about the "turbulence" and how great it is. the thing is, that turbulence slows the flow velocity, which tends to decrease the ability to wash debris out of the pipe. hes demonstration is just laughable. Notice there there's no attempt to have a comparison to perforated straight PVC. As someone else said, you put a garden hose in straight pipe and it will clean that out too, guaranteed.
About the only useful information in the video is him saying that installing tile with low spots causes problems. Everything else is pretty much just Vince selling ShamWow
Not to claim that flexible corrugated tile is a scam. It's not, just that this video isn't any kind of demonstration of the performance of the tile, just an advertising pitch.
huesmann likes this.
A Squared is offline   Reply With Quote
Old 03-25-2020, 01:36 PM   #49
retired framer
Rewards Points: 8,500
Do not use flat bottom gables with scissor trusses.
Old 03-25-2020, 04:01 PM   #50
I agree completely with joecaption, and think it may be even higher - 95%+ of the problems are outside. I have a home in the Boston area and another in southern Maine, and had major problems in both with water in my basement. Both have been solved - the one in Boston needed the gutters extended with corrugated piping more than 20' away from the foundation. The one in Maine required grading away from the foundation plus an 18" trench with corrugated piping carrying the water all the way to the edge of the street. It's covered with river stones and looks great, and as I said both homes have been bone dry since getting these fixes implemented. Good luck and hope this helps.
rcspencer1 is offline   Reply With Quote
Old 03-25-2020, 04:05 PM   #51
retired framer
That is always number one but digging around the outside with driveways and patios is often really costly.
Old 03-26-2020, 06:51 PM   #52
Rewards Points: 3,018
God never meant for man to live in caves as He gave us the ability to think for ourselves,,, that being said, yes - basements CAN be dry, useable, enjoyable, & add many sf to a home.
'french drains' are so named due to the method used by french architects to manage rainwater at the versaille courtyard,,, paving stones were laid in such a manner as to direct all rainwater to the left flowing under the hall of mirrors & feeding the reflective gardens,,, today the term is misunderstood by the bewildered but, nevertheless, it is NOT a sub-floor leak management system,,, in landscaper's terms, a fr drain becomes a berm or swale.
surface wtr is usually NOT cause of basement leak - usually its bldg code which STILL only specs for 'dampproofing', NOT waterproofing
h/o wallet's generally prime reason for interior as opposed to exterior work,,, remember 1 time waterproofing a 6,000sf home on TOP of a mt in pa
stadry is online now   Reply With Quote
Old 03-26-2020, 08:08 PM   #53
FM3
Rewards Points: 84
Never heard anyone call them french drains for reasons other than American Henry French.
"Henry Flagg French was an assistant secretary of the Treasury of the United States under Ulysses S. Grant and he was very fascinated with agriculture.
he published a book titled “Farm Drainage” in 1859, and it is considered the definitive research text on drainage...The conclusion of his book resulted in the invention of the French drain, an excavated trench that is filled with gravel and a perforated pipe that serves to carry away accumulated water."
Here's a scanned version of Henry French's book if anyone wants to read it:
http://www.archive.org/stream/farmdr.../search/french
More fun facts: Henry French is the father of sculptor Daniel Chester French who created the statue of Abraham Lincoln central to the Lincoln Memorial.
Nealtw likes this.
FM3 is online now   Reply With Quote
Old Yesterday, 05:40 AM   #54
i like my version better & so do our clients,,, however, should we run into any rural farm clients, i'll use your definition w/o either crediting you OR any pause
Old Today, 05:28 PM   #55
missed this comment earlier so let's address it now,,, ' The only way to fix this is install a proper foundation drain (outside your foundation) ' ,,, code spec rqmnts for foundation drains suck,,, put it in according to code & w/i 2mos, it will be worthless,,, HOWEVER, it did meet 'code' when inspected IF it were even inspected prior to backfill
nobody cares, either,,, home warranties ONLY include leaking water for the 1st year, bldrs say 'it met code', & inspectors MUST pass/fail based on code rqmnts ! ! !
