Curved Fireplace - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By MTN REMODEL LLC
  • 1 Post By jcaspar1
Old 06-18-2017, 04:00 PM   #1
Rewards Points: 20
Curved Fireplace
I am building an outdoor fireplace. It is a modular masonry unit surrounded with cinder block. My wife would like the sides to be curved and finished with stucco like this:
I am trying to figure how to do this. I was planning on approximating the curve with small 2" steps of cut cinder block and concrete bricks, then filling in the steps with mortar. Is there a better way to do this? Here is what it looks like now and the section of rebar approximates the curve I am looking for. The block under the rebar are just setting there right now. any suggestions would be greatly appreciated!
jcaspar1 is offline   Reply With Quote
Old 06-18-2017, 04:16 PM   #2
Rewards Points: 20
Re: Curved Fireplace
Sorry. Photos didn't work and can't edit. Here they are:
Old 06-18-2017, 04:24 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 738
Still a little small....
Nik333 likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 06-18-2017, 04:27 PM   #4
Rewards Points: 20
Ugh. Sorry. I don't have the paperclip icon to link photos and the insert image tab apparently is not working. Tried to change to advance settings but it won't let me. I do have emojis though!
Nealtw likes this.
Old 06-18-2017, 06:00 PM   #5
kwikfishron's Avatar
Rewards Points: 178
Here's your pictures, I think 3rd pic is supposed to be the first (I tried).
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
jcaspar1 (06-19-2017)
Old 06-19-2017, 09:07 PM   #6
Concrete & Masonry
Rewards Points: 464
I would use concrete brick instead of block, as they're far easier to corbel and require much less mortar. We've done similar FP's in the past, and have always plastered with mortar in a few stages to avoid cracking. Keeping the mortar wet as long as possible obviously helps also.
jomama45 is offline   Reply With Quote
Old 06-22-2017, 11:38 PM   #7
Rewards Points: 20
Thanks Jomama. I appreciate the advice. So if I understand you, do a stepped pattern of cement bricks such that the corners approximate the curve, then fill in the steps with mortar to compete the curve? Something like this?:
Laminate Flooring around Curved Fireplace Dallas Flooring 10 11-14-2019 10:10 AM
Curved fireplace Rgonz1974 Concrete, Stone & Masonry 1 07-09-2015 10:15 AM
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 09:09 PM
What to do with a huge curved fireplace?? tkh1225 Interior Decorating 8 12-17-2011 10:04 PM
What to do with a huge curved fireplace?? tkh1225 Remodeling 7 11-30-2011 05:00 PM
