Convert Wood Burning Fireplace To Double Sided - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-02-2014, 10:02 AM   #1
Rewards Points: 434
Convert wood burning fireplace to double sided
Can someone educate me on how feasible and costly it would be to convert this fireplace to open up to the other side of the room?
I'm open to all suggestions. I'd also like to consider opening it to 3 sides (den, dining and kitchen) and doing a gas insert and seal off the flue.
There is a header beam at the top of the ceiling just above the fireplace that is running left to right that you can better see in the two pics below:
vestaviascott is offline   Reply With Quote
Old 10-02-2014, 02:01 PM   #2
Rewards Points: 434
Or, if 3 sides open is not feasible or cost effective, I'd settle for double sided. Anyone?
Old 10-02-2014, 02:38 PM   #3
Rewards Points: 434
..Or alternately, removing the brick fireplace and surround altogether and installing a triple sided gas unit where the theromostat control area is. That would free up lots of floor space.
Ultimately, I'd need to get a structural engineer's assessment obviously.
Old 10-03-2014, 09:13 AM   #4
Rewards Points: 434
Just looking for some contractor input here. Anyone have any suggestions or comments?
Perhaps to deal with any potential structural issues, I could create a four sided 1/4" steel box to line the inside of the firebox with, transferring the back wall weight and then convert the fireplace to gas with a vent up through the top. Ideas?
Old 10-06-2014, 09:53 AM   #5
Rewards Points: 434
Any feedback at all would be appreciated. Thanks in advance.
Old 10-06-2014, 02:11 PM   #6
Rewards Points: 3,622
its certainly feasible & possible,,, cost may be surprising/shocking/unaffordable,,, pricing isn't usually discussed often as costs vary across the posting area that may account for the lack of responses
Old 10-06-2014, 02:28 PM   #7
Rewards Points: 434
Thanks Stadry. I don't have to have specifics on cost. I'm just looking to get a better understanding of the complexity of the project. To the extent you can tell from the pics I've provided.
Specifically, does it appear that opening the FP to both sides would create significant structural issues?
Especially in light of the presence of the main support beam placement above it.
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 08:09 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Encasing a brick fireplace in wood Laborfree Carpentry 3 10-23-2011 07:40 PM
Pros and Cons of Burning Wood, need help ChrisDIY HVAC 9 09-23-2011 04:32 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
