Concrete Tree Bed Edging Beams - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-27-2017, 10:36 AM   #1
Rewards Points: 14
I have a bunch of fruit trees built up on mounds. Here in rainy south Florida you have to get the tree roots up out of the summer wet for the tree to survive. I have the beds built inside hexagons built from 2" x 8"s. The hexagons are 71" sides and about 12' major diameter. The deck screws are pulling out of the decaying wood and the joints are opening up. I was thinking about rebuilding with pressure treated 4" x 8" timbers, but thought I might consider similar sized DIY concrete beams. Each of the six hexagon corners sit on a brick so the edges of the sides do not sit on top of the soil. A beam would have to tolerate it's own weight being suspended between it's edges as well as the pressure of the bed soil pushing out.
Would a DIY 4" x 8" concrete beam work as described above or would a different dimension be better? How much rebar of what size would be needed? Would any type of pre-stressing be needed? How would you connect the sides, I was thinking about a half-lap style joint.
dshcs is offline   Reply With Quote
Old 05-27-2017, 06:17 PM   #2
Rewards Points: 1,042
Re: Concrete Tree Bed Edging Beams
I'd go with the pressure treated, and seal the cut ends with paraffin before putting them together.
Canarywood1 is offline   Reply With Quote
Old 05-27-2017, 07:59 PM   #3
Rewards Points: 1,956
Why don't you also look at those interlocking precast concrete blocks from the home center? There are some that are curved.
ChuckF. is offline   Reply With Quote
Tags
beam , concrete , rebar , stress
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
ultimate concrete hardness Yodaman Concrete, Stone & Masonry 12 05-04-2015 06:47 PM
Concrete Tree Face Syscokid 1 Concrete, Stone & Masonry 2 03-03-2012 10:41 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
concrete grade/bond beams under slab? jklingel Building & Construction 7 12-22-2008 12:43 PM
