Concrete Step From Garage Into House - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-15-2014, 01:27 PM   #1
Rewards Points: 4
Concrete Step from Garage into House
Our garage is 12 inches lower than the house and a step was never built so we are currently using cinder blocks. I would like to make a concrete step into the house that is long and wide so the kids have a place to sit and put on shoes. The door is in a corner so two sides of the step would be against drywall. The garage floor is concrete. I know you shouldn't pour concrete against dry wall so I should cut the dry out and add wood to fill the space and build the form. I would clean/roughen the floor with concrete cleaner then soak the area with water. Pour the concrete in the form, trowel smooth, cure/cover. Is there anything I am missing? Should the step adhere correctly? Any advice or suggestions are greatly appreciated.
Msgrun is offline   Reply With Quote
Old 10-15-2014, 01:49 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 692
I would built a box with PT lumber and use Trex for the step.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 10-15-2014, 01:51 PM   #3
47_47's Avatar
Rewards Points: 320
Have you considered making a pressure treated 2 x 6 frame on edge with a plywood top? You could screw the 2 x 6 into the existing wall to prevent it from moving.
47_47 is offline   Reply With Quote
Old 10-15-2014, 02:39 PM   #4
Rewards Points: 4
I would but there is another door that leads to the deck that does have a concrete step and I would like them to match.
Old 10-15-2014, 03:21 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 23,958
Concrete against wood or drywall is not a good idea. I would build a wooden step.
If you have to have a concrete one then use pressure treated lumber against the wall. Or just buy a precast concrete step. You can buy a single step.
The Following User Says Thank You to joed For This Useful Post:
rjniles (10-15-2014)
Old 10-15-2014, 04:34 PM   #6
Rewards Points: 1,042
If it has to be concrete, cut out the drywall portion and replace it with cement board, then build the form as you normally would, just be sure you make the cutouts a little wider than you actually need them to be.
http://www.homedepot.com/p/DUROCK-Ne...2965/202263276
Canarywood1 is offline   Reply With Quote
Old 10-16-2014, 10:28 AM   #7
Rewards Points: 2,456
try as you might, they won't match - neither color NOR texture we often repair conc & the 1st thing we do is manage customer expectations especially regarding color
Old 10-16-2014, 06:19 PM   #8
I agree on color, texture is iffy but you just never really know until it's done.
Add 14-50 240v 50amp plug in garage or Add entire panel and 240v plug on Old House. wowor Electrical 9 06-06-2013 02:54 PM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
House wall between house and garage BlueBSH Drywall & Plaster 3 06-19-2010 09:13 AM
direct bury wire from house to garage??? help vinylman70 Electrical 30 01-20-2010 09:44 PM
