Concrete Slab Phantom Front - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree3Likes
  • 2 Post By joed
  • 1 Post By Canarywood1
Old 08-16-2016, 11:12 AM   #1
Rewards Points: 2
We are hiring a concrete patio poured in our back yard. The contractor has framed it up and brought in gravel to prepare for the pour, but I don't understand what he's doing. He framed an external structure and an internal structure of wood that he backfilled inside of. That internal structure leaves a 9" wide by 9" deep "footing" to the outside at 3 of the 4 sides of the patio where the yard falls away. He plans on pouring the full patio which will encapsulate the internal wood structure. When I called out that it will rot out, he informed me that was to plan and would rot out in 6-7 years leaving an intentional void. He called it a "phantom front" or something like that.I can't find anything by that name on the web. So when it's finished we will eventually have a 4" thick slab with a roughly 1.75" wide x 9" deep void under it on 3 sides. Is this a real technique? Can someone explain the purpose of this practice? I am attaching a couple of pics. Thanks in advance. It's our first home so we have lots of DIY, lots of hiring, and lots of questions!
Concrete Slab Phantom Front-20160816_102841.jpg   Concrete Slab Phantom Front-20160816_103008.jpg
Thatguy77 is offline   Reply With Quote
Old 08-16-2016, 11:29 AM   #2
Rewards Points: 4,760
Re: Concrete Slab Phantom Front
Not my area of expertise but I certainly understand your hesitation....
stick\shift is offline   Reply With Quote
The Following User Says Thank You to stick\shift For This Useful Post:
Thatguy77 (08-16-2016)
Old 08-16-2016, 03:47 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,682
Never seen it done like that. The ones I have seen just piled the stone and sloped it. No wood frame to hold it.
The Following User Says Thank You to joed For This Useful Post:
Old 08-16-2016, 05:04 PM   #4
Rewards Points: 1,232
Normal concrete should be a minimum of 3" thick, and really 4" thick. His idea is OK, but not normal, and voids under concrete are often done intentionally, but I would insist on a minimum edge thickness of 4".
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 08-16-2016, 05:06 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,054
Ayuh,.... No idea what yer contractor is doin',.....
Never seen such a thing,...
Like Joed says,...
We form up the outside, sculpture the compacted stone inside it, lay the steel, 'n pour the concrete,....
Looks like a future fracture line to me,....
The Following User Says Thank You to Bondo For This Useful Post:
Old 08-16-2016, 05:23 PM   #6
Also, the way he has it formed, it is creating a fracture plane right at the worst place, the edge. His "phantom front" is likely to crack off as formed.
Old 08-16-2016, 05:55 PM   #7
Rewards Points: 18,806
I've worked with at least 6 different concrete finishers on at least 100 different slabs and I've never seen it done that way.
Just does not make logical since to me.
I like to see a turned down edge on a slab to make it stronger and less chance of it washing out.
Sort of like this.
https://www.google.com/search?q=turn...RV0aKYtW4eM%3A
No way would I except what he has done.
Old 08-16-2016, 06:27 PM   #8
Super Moderator
joed's Avatar
I never thought about the cracking but I agree. Any square sharp corner is going to crack.
This is what I would expect to see.
Msradell and joecaption like this.
Old 08-16-2016, 08:29 PM   #9
Rewards Points: 1,042
35 years in the ready-mix business, and never seen anything framed like that.
joecaption likes this.
Canarywood1 is offline   Reply With Quote
Old 08-17-2016, 08:09 PM   #10
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
I also poured a lot of slabs as a mixer driver, don't remember ever seeing that. Not even sure of the logic behind it.
I hate signatures.
Mort is offline   Reply With Quote
Old 08-17-2016, 09:25 PM   #11
Msradell's Avatar
Rewards Points: 1,104
Like everyone else is that I've never seen anything like that at all in residential or industrial situations. I certainly wouldn't accept it as a normal procedure. Your profile didn't state what part of the country you're in. If you are in an area where frost is a consideration it's even worse!
What joed showed in the picture you posted is what I seen everywhere that I've been around.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Tags
concrete , patio , phantom front
Trying to install pavers or tile over concrete slab in questionable condition sallen Landscaping & Lawn Care 1 07-10-2016 08:43 AM
Pouring a concrete slab ponch37300 Concrete, Stone & Masonry 11 02-18-2015 05:33 PM
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 04:24 AM
Concrete Front Porch Structure bheher Building & Construction 1 10-17-2011 09:56 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
