Concrete Sealed Too Soon? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree4Likes
  • 1 Post By mark sr
  • 1 Post By Yodaman
  • 2 Post By Canarywood1
Old 06-26-2017, 09:11 PM   #1
Rewards Points: 6
Concrete sealed too soon?
I have concerns about a slab I had poured last week for a garage I am building. The contractor returned the very next day to cut in the lines and apply sealer. Now the entire slab looks like the pics! Was it sealed too soon? Or is something else going on here? He claims the appearance will even out, but all the discoloration and streaks are trapped under the sealer! I looks horrible! I welcome your thoughts...
jhenry1745 is offline   Reply With Quote
Old 06-27-2017, 06:22 AM   #2
retired painter
Rewards Points: 1,830
Re: Concrete sealed too soon?
What sealer did he use? Most use a sealer that helps cure the concrete and is usually applied within 24 hrs of the pour. If it's a clear 'paint' type sealer you'd probably need to wait 30 days.
jhenry1745 likes this.
mark sr is offline   Reply With Quote
Old 06-27-2017, 07:59 AM   #3
Property Mgt/Maint
Rewards Points: 7,624
"When to applyWhen you apply sealer can be important as well. Allow new concrete to cure completely (at least 28 days or as recommended). Most sealers must be applied under dry conditions, since applying sealer to damp concrete could cause haziness or loss of adhesion. Air temperatures are also important and should typically be above 50°F during and for at least 24 hours after sealer application. Always allow the sealer to dry completely before exposing it to foot or vehicle traffic. Drying times before exposure to heavy traffic can be as long as three days."
I think the key for you is find out what was put down and what the specific mfg's guidelines are for new concrete.
Good Luck
https://www.concretenetwork.com/conc...alingplain.htm
Yodaman is offline   Reply With Quote
Old 06-27-2017, 03:57 PM   #4
Rewards Points: 1,042
If he used a combination curing and sealing compound it's okay, otherwise follow the mfg's. directions, he did the right thing on cutting the control joints.
stadry and jhenry1745 like this.
Canarywood1 is offline   Reply With Quote
Old 06-27-2017, 04:52 PM   #5
Rewards Points: 6
It's a thick application and shows a lot of depth. I'll find out tonight what was used.
Not a fan of the splotchy spots and streaks!
Old 06-27-2017, 08:18 PM   #6
How old is the slab??
Old 06-27-2017, 08:31 PM   #7
Rewards Points: 6
One week.
Old 06-27-2017, 11:09 PM   #8
Concrete & Masonry
Rewards Points: 464
Was there plastic sheeting/visqueen laying on the slab early on? That looks like the cause of most of the streaking to me.
Obviously, as others have said, the kind of sealer is important as well. We use water-based cure seals that we literally follow the broom with. Most solvent-based sealers require more cure time to work correctly.
jomama45 is online now   Reply With Quote
Old 06-28-2017, 11:16 AM   #9
Originally Posted by jhenry1745 View Post
One week.
Give it another 2/3 weeks and it should clear up.
Sealed concrete maddog1 Painting 6 03-08-2015 08:29 PM
Are my concrete piers doomed to fail? Pharm80 Concrete, Stone & Masonry 6 09-11-2014 01:03 PM
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
