Concrete Piers - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-15-2014, 04:06 PM   #1
Rewards Points: 528
concrete piers
When pouring concrete piers in the tubes for a deck ,i will build on top later, do the tubes need to go all the way to bottom of holes where the drainage rock is ? .Also what is the depth for holes -is in TN.Its a 24 by 12 ft deck.and piers will be about 3-4 inches above ground . im using the 8 inch wide tubes.Also will i need reinforcement at all?
Any other tips are appreciated.
hidden1 is offline   Reply With Quote
Old 10-15-2014, 04:13 PM   #2
Rewards Points: 1,042
No they only need to be the height you want above grade, and the frost line in Tennessee is 18/20 inches.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
RockyMtnBlue (10-15-2014)
Old 10-15-2014, 04:56 PM   #3
Rewards Points: 38
I used 12" tubes without reinforcing steel. Not testifying to "correctness", just saying that's what I did.
RockyMtnBlue is offline   Reply With Quote
Old 10-16-2014, 09:26 AM   #4
You didn't need rebar!!
Old 10-16-2014, 01:29 PM   #5
concretemasonry's Avatar
Rewards Points: 2,716
You just need good soil to pour the concrete on. Rock is not needed since concrete does not rot and is poured on saturated soils or under water every day. Most of the rock eventually get pushed into the soil at the base.
The larger the diameter of the Sonotube, the better for use on poorer soils. Rebar is not needed, but can be used for a warm and "fuzzy"satisfaction.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
RockyMtnBlue (10-25-2014)
Concrete Deck Repair (BIG JOB) vector006 Concrete, Stone & Masonry 25 10-12-2013 06:07 PM
Concrete Sealer For Home Patio & Sidewalk JasonCA Concrete, Stone & Masonry 1 01-22-2013 02:28 AM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Reinforce concrete piers? Neil_K Building & Construction 8 11-21-2004 06:53 PM
