Concrete Patch - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By Bondo
  • 1 Post By bob22
Old 06-14-2017, 08:50 AM   #1
Rewards Points: 650
Concrete patch
The edge of my patio has some voids in the concrete that I would like to patch. What would be the best concrete mix/patch to use to fill in this void area to fix the appearance?
I have a spare 80 pound bag of "High Strength" concrete mix. I'm not sure if that's the best to use since it has pretty large gravel in the mix. If I mix this thick, will it adhere to the underside of this void to patch it?
Or should I spring for a few bags of the 3 pound "Concrete Patch" to do this?
homeimproverjoe is offline   Reply With Quote
Old 06-14-2017, 09:48 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 262
Re: Concrete patch
Ayuh,.... Take 2 steps back, 'n snap another picture,....
What's under that picture,..??
bob22 likes this.
Bondo is online now   Reply With Quote
Old 06-14-2017, 11:51 AM   #3
Rewards Points: 650
Re: Concrete patch
Just need to smooth out this edge, especially the uneven voids on the underside before I install the pond liner in the pond which this patio partially overhangs (by appx 4-6 inches)
Old 06-15-2017, 08:54 AM   #4
Rewards Points: 650
Re: Concrete patch
I'd like to get this done today. Will the 80 pound concrete mix work for this or do I need a specialty mix here? Thanks for the help.
I'll be using wood boards below and on the side to hold the concrete in place while it cures.
Old 06-15-2017, 09:36 AM   #5
Rewards Points: 2,510
Re: Concrete patch
Will the concrete go from underneath the top ledge and down to the surface, like a riser on steps? If so, I think you could use anything. If it has to hang under the top ledge, then perhaps some Tapcons or similar to help the scab hang on would help.
A concrete guy's experience would be helpful; one of them will likely comment.
I wouldn't rush it; would suck to do over IMO.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
homeimproverjoe (06-15-2017)
Old 06-15-2017, 10:28 AM   #6
Rewards Points: 650
Re: Concrete patch
The concrete will only go in the void shown in the pic. The result will be a clean edge vs what I have now which has two voids along the patio edge.
Pics below. The green overlays show where the concrete patch will go.
Old 06-15-2017, 10:36 AM   #7
Rewards Points: 3,630
Re: Concrete patch
Flowing into and completely filling the cavity is paramount in this instance so I would be using Rockite.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 06-15-2017, 10:57 AM   #8
Rewards Points: 650
Re: Concrete patch
We don't have Rockite at any local HD or Lowes or hardware store I can find.
I'm considering these:
http://www.homedepot.com/p/Rapid-Set...0025/202207958
http://www.homedepot.com/p/SAKRETE-6...0024/100321207
Old 06-15-2017, 11:21 AM   #9
Re: Concrete patch
If I'm choosing, I'd go for the first one based only on the package words.
concretemasonry likes this.
Old 06-15-2017, 12:00 PM   #10
Rewards Points: 1,042
Re: Concrete patch
If you only want to patch the green area, you need grout mix, or hydraulic cement would work also, the smaller container the better for your needs.
http://www.homedepot.com/p/Quikrete-...8520/100318454
Canarywood1 is offline   Reply With Quote
Patch Hole in Concrete Wall electronicsfrea Concrete, Stone & Masonry 3 02-27-2017 04:17 AM
What concrete to patch where spigot was ??? steve3847 Concrete, Stone & Masonry 1 11-06-2013 09:17 PM
Mortar or Concrete basement patch form? bansheex General DIY Discussions 3 01-30-2012 01:41 PM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
