Concrete Next To Window Wells - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree4Likes
  • 3 Post By jomama45
  • 1 Post By stadry
Old 04-17-2017, 11:55 AM   #1
Rewards Points: 6
Concrete Next to Window Wells
Hi All,
I am installing a new concrete patio extension next to an existing concrete patio and my house. I have installed an expansion joint against the concrete foundation of my house taking into consideration a slope away from the house, but I also have a couple window wells and a corrugated drain access tube in my pour area.
What kind of material or expansion joint do I put around my window wells so I can pour concrete there?
Also, should I install an expansion joint on the existing patio concrete or will a control joint in the new concrete be sufficient?
Thanks!
Quatto is offline   Reply With Quote
Old 04-17-2017, 11:55 AM   #2
Rewards Points: 6
Re: Concrete Next to Window Wells
Here is a picture of the work area
Old 04-17-2017, 04:46 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,872
I would create a bit of a gap via some sill plate gasket material or some peal and stick membrane.
https://www.google.com/shopping/prod...FZqNswodw_QEKQ
Old 04-18-2017, 10:28 PM   #4
Concrete & Masonry
Rewards Points: 458
We use WR Meadow's "Deck-O-Foam" in 1/2" for almost all of our installations around window wells. If you can find the rubber expansion joint, that will follow the radius of the window wells, also.
I wouldn't (won't) install expansion material between new and existing, unless I am expecting the two slabs to move independently, and "hinge" a lot at the joint.
Bondo, Windows on Wash and stadry like this.
jomama45 is offline   Reply With Quote
Old 04-19-2017, 01:26 AM   #5
Rewards Points: 6
Thanks a ton for the tips. I've used that deck o foam against the house and I will certainly look at putting it around the window wells then.
How do you get it to sit flush to the window wells? I used liquid nails to secure it to the house, but I'm not sure how to best secure it around the window wells.
Thank you so much!
Old 04-19-2017, 08:58 AM   #6
Rewards Points: 2,752
why not remove the window wells instead ? from the pics, they're not doing much good
concretemasonry likes this.
stadry is online now   Reply With Quote
General window install questions miamicuse Windows and Doors 9 04-23-2013 09:05 PM
Changing Window Size TinaV Remodeling 3 11-06-2012 01:30 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Vinyl Window in Concrete Block Wrongwrench Carpentry 4 12-07-2010 11:21 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
