Concrete Floor Subbase Material - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-17-2016, 03:35 PM   #1
Rewards Points: 4
Concrete floor subbase material
I want to pour a concrete pad for building a shed 12'x16' on top and I am shopping for subbase material.
I found a few suppliers that offer 3/4" crushed limestone, 5/8" clear crushed, 1-1/2" to 0" crushed concrete (is this mean the aggregate will be 1-1/2" and smaller?) which one of these is best?
Thanks!
Sunapollo is offline   Reply With Quote
Old 05-17-2016, 09:19 PM   #2
Concrete & Masonry
Rewards Points: 458
Re: Concrete floor subbase material
I prefer the first, the 3/4" crushed limestone. Once compacted and wetted down, it's very firm and won't move around.
The second has no fines, and moves around too mch IMPO. The third is too larger to handle by hand IMPO.
jomama45 is offline   Reply With Quote
Old 05-18-2016, 09:09 AM   #3
landfillwizard's Avatar
Rewards Points: 618
I agree with jomama! Before placing the crusher run stone, remove all top soil and nay other organic material found under the the area you are going to use for the pad. Place fabric on top of the sub-base and compact the crushed gravel in 3" lifts. I would place a minimum of 8" of base below the concrete for that size of building.
landfillwizard is offline   Reply With Quote
Old 05-18-2016, 10:17 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,908
Ayuh,.... I agree as well,... Use option 1 or 3,....
3/4" minus is just easier rakin' than 1, 1/2" minus,....
Both are a stable solid base material,.....
Old 05-18-2016, 02:09 PM   #5
Rewards Points: 4
Thank you all. Just to clarify, I should place landscape fabric first on soil then put the crushed rock on top of fabric and compact well. Afterwards, a layer of vapor barrier on compacted crushed rock then pour concrete?
Old 05-18-2016, 07:17 PM   #6
Rewards Points: 1,042
There's no need for a vapor barrier!
Canarywood1 is offline   Reply With Quote
Concrete and Brick Repairs spidercharm Building & Construction 6 08-26-2012 05:15 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 07:11 AM
