Concrete Deck Footings...below Freezing Question - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By Mort
Old 02-06-2019, 03:04 PM   #1
Rewards Points: 152
concrete deck footings...below freezing question
Hello,
we are beginning to build the deck Saturday...the High is 35 and the low is 23
how concerned should I be with the concrete footings going in that day if accelerator is used?
I've heard it being very frowned upon but I have also heard of no issues with concrete setting below freezing....
it will also be quicksetting concrete and not a large surface area, just deck footings
thoughts? thanks
ny86yanks is offline   Reply With Quote
Old 02-06-2019, 07:53 PM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
Re: concrete deck footings...below freezing question
I wouldn’t bother with accelerator. It just helps the initial set come faster, it doesn’t gain strength any faster. I’d wait at least 7 days before subjecting it to any load, unless you have concrete using Type III cement (hi-early).
As far as the temperature, eh, I’ve poured in colder. Just cover it with blankets after initial set to keep as much heat in as possible.
I hate signatures.
Mort is offline   Reply With Quote
Old 02-06-2019, 08:02 PM   #3
Rewards Points: 152
thank you
the deck footings will be down about three feet so just cover the holes after?
Old 02-06-2019, 08:25 PM   #4
Mort's Avatar
Rewards Points: 696
It’d be best to cover them as closely as possible, like with a blanket, but as long as they’re covered that’s better.
ny86yanks likes this.
I hate signatures.
Old 02-07-2019, 04:21 AM   #5
Nailed it Mort. I have to recommend that you try to get to that 4 feet. Just to be safe. Concrete blankets aren’t cheap but at least use a 6 mil BLACK poly and keep it covered as long as you can.
DZthompsen is offline   Reply With Quote
Filling voids under concrete pool deck Ralph III Concrete, Stone & Masonry 9 01-28-2019 09:47 PM
Offsetting deck "posts" on footings red92s Building & Construction 2 08-10-2017 08:49 AM
Issue with deck flashing. How concerned should I be? pasalott Building & Construction 2 09-24-2016 10:18 AM
Concrete ourcrop/bunker repair under deck BelgianBillie Concrete, Stone & Masonry 5 07-21-2015 12:43 PM
new second story deck stair, platform question walt1122 Building & Construction 10 11-12-2010 10:52 AM
