Concrete Blocks - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree4Likes
  • 2 Post By HenryMac
  • 1 Post By mark sr
  • 1 Post By rusty baker
Old 08-11-2019, 02:43 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,376
concrete blocks
Will concrete blocks fall apart if exposed to fire repeatedly?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 08-11-2019, 03:21 PM   #2
Rewards Points: 1,406
Re: concrete blocks
Here is more than I care to read but maybe it will get you a start....https://www.emcoblock.com/pdf/divisi...ce-ratings.pdf
Gregsoldtruck79 is offline   Reply With Quote
Old 08-11-2019, 04:02 PM   #3
Re: concrete blocks
Thanks. Trying to save a little money. Building a fire pit to fire pottery. I have a bunch of blocks left over from a project at another house. The pottery will be fired in a barrel. But It will need blocks around and under the barrel.
Old 08-11-2019, 06:05 PM   #4
HenryMac's Avatar
Rewards Points: 996
Re: concrete blocks
One thing to consider: If the blocks are outside and permitted to get wet and then you fire the pit, the water in the block boils and it cracks the block.
We had a fire pit that used red sandstone caps. After a rain we made a fire in the fire pit. Pieces of the sandstone were exploding and raining down on us shortly thereafter.
Nik333 and Nealtw like this.
HenryMac is offline   Reply With Quote
Old 08-12-2019, 05:01 AM   #5
retired painter
Rewards Points: 1,298
Re: concrete blocks
Concrete blocks deteriorate when exposed to fire, you need to either use fire brick or natural stone. But if I understand you correctly - the block won't be exposed to fire, just heat?
mark sr is offline   Reply With Quote
Old 08-12-2019, 05:15 AM   #6
JUSTA MEMBER
Rewards Points: 3,476
Re: concrete blocks
Plain average concrete block will fall apart after repeated use in this way.
I have seen solid Granite, start to come apart, after repeated use as a fire pit also, So use some kind of protection, like a fire ring, or other way to isolate your block from most of the intense heat generated in a homemade kiln, for pottery.
Or use real Firebrick as a liner.
ED
de-nagorg is offline   Reply With Quote
Old 08-13-2019, 04:22 PM   #7
Re: concrete blocks
Just heat. The barrel will get the direct fire.
Old 08-13-2019, 10:31 PM   #8
JUSTA MEMBER
Re: concrete blocks
Is this barrel, a typical 55 gallon oil drum?
If so they last for a while, but eventually rot out from the heat and rust.
Remember when it was legal to burn your household garbage in one?
How long did it last, until a person needed to replace it?
5 years maybe, depending on how often you burned the trash.
ED
Old 08-14-2019, 04:17 AM   #9
retired painter
Re: concrete blocks
I still burn my trash in a 55 gallon drum a few times a week. Before I started putting a lid on it to keep the rain water out they only lasted a yr or two. Now I get 5 plus years out of a burn barrel. Not all 55 gallon drums are equal, some are stouter than others.
de-nagorg likes this.
Old 08-14-2019, 07:47 AM   #10
Re: concrete blocks
ED
The local college has pit fired in the same barrel for years. Pit firing gives a different look than kiln fire.
Old Today, 04:47 PM   #11
Rewards Points: 2,194
Re: concrete blocks
even a granite faced fireplace is lined w/firebrick & mortar,,, exploding rock's like a grenade to anyone in the effective kill zone
Old Today, 09:27 PM   #12
Rewards Points: 4,134
Re: concrete blocks
Have you thought about.?
ron45 is online now   Reply With Quote
