Concrete Block To Tile? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-17-2016, 12:18 PM   #1
Rewards Points: 4
Concrete Block to Tile?
I'm looking to build a riser for my wood stove and the requirements for the stove say it must be masonry/concrete. I can't have any wood in the riser as my stove has no bottom heat shield.
Currently the stove is sitting on tile over a concrete slab. I'm thinking of using 4"x8"x16" concrete block to build up the riser, then tile over that. I read that you can tile over tile if you sand it down, but is it okay to use concrete block over tile? If so, would thinset be enough or would I need a different type of mortar? Guessing this is an odd scenario. I don't want to break out the current tile on the floor if I don't have to.
I'm thinking it would be do-able but am not sure of the mortar to use.
lakeshiner is offline   Reply With Quote
Old 08-17-2016, 01:19 PM   #2
Rewards Points: 4,814
Re: Concrete Block to Tile?
I would cut out the tile.
stick\shift is offline   Reply With Quote
Old 08-17-2016, 06:38 PM   #3
Concrete & Masonry
Rewards Points: 518
I wouldn't be concerned about the block adhereing to the tile, especially if you set the bed in thinset. I would suggest setting wider block though, because 4" wide are extremely "tippy" and hard to work with and keep plumb, even for a pro.
jomama45 is offline   Reply With Quote
Old 08-17-2016, 09:42 PM   #4
Rewards Points: 4
Thanks, I was thinking that thinset would hold it fine. I probably listed my dimensions poorly, the block is 8"x16", 4" thick. So it lays pretty flat in that regard.
My concern over taking out some tile is that I would have to replace a few in spots where I need about half a tile worth of coverage. I don't think I can get half of one out and make it look decent and I hate to dip into my spare tile supply because it was discontinued so what I have is all I can get. That's why I was thinking to go over it and not wreck any if possible.
Old 08-18-2016, 05:35 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,266
Ayuh,.... Agreed,.... Ya got gravity on yer side,...
Short of a major earthquake, it won't go anywhere,....
Bondo is online now   Reply With Quote
Tags
block , mortar , tile
How to frame around concrete block half wall in basement Studly Remodeling 12 11-28-2014 09:55 PM
Need A Solution Where Block Meets Concrete dankoos Concrete, Stone & Masonry 13 04-14-2014 11:38 AM
concrete block sealer meeotch Concrete, Stone & Masonry 4 04-08-2014 10:05 AM
Can I install ceramic tile onto an uneven and un-level concrete floor? Integraoligist General DIY Discussions 17 02-03-2011 08:43 PM
Ceramic floor tile on concrete basement floor w/toilet pedestal amp2oo1 Flooring 1 10-05-2009 07:31 AM
