CMU Retaining Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By landfillwizard
  • 1 Post By stadry
Old 06-25-2019, 07:36 AM   #1
Rewards Points: 2
CMU retaining wall
Ok guys here is my project. I have a wall I want to build. 8x8x16 cmu block. going to veneered on the face. it will hold soil about 3' high at the highest point then taper down.
I am going to dig to frost line then pour 12 inch footer. Set block. fill cores. rebar in footer thru block. drain stone behind and drain pipe. Am I miising anything ?
Should I put batter on the block or lay the block plumb ?
chardscapes is offline   Reply With Quote
Old 06-25-2019, 09:53 AM   #2
landfillwizard's Avatar
Rewards Points: 618
Re: CMU retaining wall
Where do you live?
de-nagorg likes this.
landfillwizard is offline   Reply With Quote
Old 06-27-2019, 07:46 AM   #3
Rewards Points: 2,698
imo, you're better served by block engineered wall,,, https://www.concretenetwork.com/conc...tal_retaining/ ,,, however, it is your home & your $$$
Nealtw likes this.
