Chimney Or House Bracket To Mount Weather Station - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree8Likes
  • 2 Post By lenaitch
  • 2 Post By ChuckTin
  • 1 Post By Windows on Wash
  • 2 Post By surferdude2
  • 1 Post By surferdude2
Old 11-21-2019, 10:46 AM   #1
Rewards Points: 20
Chimney or house bracket to mount weather station
good morning
i'm considering mounting my weather station anemometer to my chimney. Can anyone recommend a bracket for this purpose. The meter is fairly light and will be mounted on a 7 foot section of one inch pvc pipe so I don't want overkill something simple. I need some clearance for one or two courses of bricks which extend out a couple of inched near top of chimney.
I would also consider mounting on eve of gable end of house. Need to see how much i need to clear the eve. maybe 8 inches or so. suggestions for either or both would be appreciated.
thank you
bobbythehunter is offline   Reply With Quote
Old 11-21-2019, 06:36 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,788
Re: Chimney or house bracket to mount weather station
Wouldn't put anything on 1" PVC. It photo degrades and gets to be super brittle.
Run a section of stainless or galvanized pipe and you can mount via masonry anchors into the mortar and some pipe clamps.
Old 11-21-2019, 08:07 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 684
Agree with WoW on using metal. Consider a couple of stand-off brackets. As an added benefit they will give more clearance from the chimney and put the station more into the airstream.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 11-21-2019, 08:55 PM   #4
Rewards Points: 812
I used an 8' metal closet rod painted white to get my weather station high enough. The mounting bracket that @lenaitch showed seem pretty good. Also, you can use a tripod that you would mount a TV antenna to. It goes over the ridge of your roof, tow legs on one side, one on the other and the mast in the center. They run about $30 US on Amazon.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 11-22-2019, 05:51 AM   #5
Rewards Points: 102
I used the stand off brackets, from Amazon and a piece of chain link (fence) top rail.
lenaitch and ktownskier like this.
ChuckTin is offline   Reply With Quote
Old 11-22-2019, 06:49 PM   #6
Rewards Points: 20
Lenaitch, can I screw these into the brick? Or do i screw it into the mortar? and how do you do this? masonry bit to tap hole?
thanks
Also is there a lightning risk using a metal pole for mounting?
Old 11-22-2019, 08:15 PM   #7
Mortar. Easier to fix.
Do you have a hammer drill?
A 4' pole is not going to make your house any more likely to attract lightening.
lenaitch likes this.
Old 11-22-2019, 08:32 PM   #8
Commercial. Const. ret.
surferdude2's Avatar
Rewards Points: 2,068
You may want to consider a chimney mount for an antenna that can be bought at any number of places... Lowes, Home Depot, et al... Google it.... Most of them don't require you to drill into the chimney, just use a SS strap to girdle the chimney.
Msradell and lenaitch like this.
surferdude2 is offline   Reply With Quote
Old 11-22-2019, 08:38 PM   #9
Usually Confused
lenaitch's Avatar
Rewards Points: 684
Agree with mortar vs. brick. If you do drill, use Tapcon screws - they have an more aggressive thread. I've never felt the need to use a hammer drill on mortar. You can buy Tapcon with a proper sized masonry bit.
Sic Itur ad Astra
Old 11-22-2019, 08:38 PM   #10
BTW... I'd use ABS rather than PVC since it will last a long time exposed on the roof. I'll outlast both of us. The house I had in Socal had ABS stubs on the roof for 36 years and AFAIK they're still sticking up there.
Old 11-25-2019, 02:49 PM   #11
Rewards Points: 20
thanks everyone. anyone else want to comment on lightning risk using a metal pole ? im going to HD to see what they have. will post on this thread once ive completed job
Old 11-25-2019, 03:23 PM   #12
retired framer
Rewards Points: 4,406
Just google TV antenna gear.
Do not use flat bottom gables with scissor trusses.
Old 11-25-2019, 04:51 PM   #13
Being a long time ham radio operator, I've used this type before... works great with no drilling required.
Nealtw likes this.
I need to know what continent you live on before giving advice.
Old 12-04-2019, 04:28 PM   #14
Rewards Points: 20
Thank you Everyone
Decided to go with a 10 foot metal pole (will most likely extend 6 or 7 feet above chimney) and standoff brackets with straps. I will post photos once the job is done. Saturday I hope. Missed a big blow this weekend.
Thanks again
Old 12-05-2019, 09:34 PM   #15
Rewards Points: 4,988
Maybe hang it atop the flag pole.
There's long ones and short ones.
https://www.google.com/search?q=flag...&bih=937#spd=0
ron45 is offline   Reply With Quote
