Cement Sink With Pinholes - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree3Likes
  • 3 Post By chandler48
Old 06-07-2017, 05:33 PM   #1
Rewards Points: 28
cement sink with pinholes
Hi all,
I made a sink.
The surface has a lot of pinholes and roughness. I am hoping to make some sort of slurry and fill it in. The person at HD recommended hydraulic water- stop cement.
It doesn't seem to be ideal, but I would like some input.
What do you all think?
Any good suggestions for slurries?
ESwierenga is offline   Reply With Quote
Old 06-07-2017, 07:46 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 936
Re: cement sink with pinholes
Hydraulic cement probably won't fill pin holes. If you are able to, polishing the surface with a flexible head random orbit sander using 2000 grit paper will work miracles. We do it on repairs to solid surface and it makes them almost disappear.
chandler48 is offline   Reply With Quote
Old 06-08-2017, 06:24 AM   #3
Rewards Points: 2,752
no surprise that if not trowel'd properly, you'll have roughness & pinholes,,, who's material did you use to cast the sink - 1 who specializes in polymer modified cements w/aggregates OR did you buy apron/vest store materials & watch some you tubers ?
i'm not trying to shame you but, in general, most apron/vest employees only know where most mtls are located by aisle,,, SOME stores carry cement-all / rapid set,,, IF you read the printed directions, you'll be miles ahead of the store staff
wet sanders can also help create slurry which will fill pinholes
Old 06-09-2017, 01:27 PM   #4
Rewards Points: 28
Thanks for the replies.
The sink was made by pouring into a mold. I used a cement mix with a polymer additive. I did vibrate it, but it's entirely possible I did not vibrate enough.
There are tiers on the inside of the sink so using an orbital sander on these will be tricky. I have a smaller sander that may work for the insides.
I am hoping to use a palm sander on the top surface of the sink, as I don't have an orbital sander.
I uploaded pictures to my album
Last edited by ESwierenga; 06-09-2017 at 01:38 PM. Reason: picture links didn't work
Tags
cement , pinholes , sink
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 12:18 PM
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 03:37 PM
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 04:12 PM
