Cement Mixer Question - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree7Likes
  • 2 Post By Bondo
  • 4 Post By jomama45
  • 1 Post By stadry
Old 03-30-2017, 10:29 AM   #1
Rewards Points: 132
When one purchases a cement mixer, does the specified size of the mixer denote how much concrete it will mix at once? Or is that the total volume of the bowl?
I'm thinking of purchasing one of those cheap Harbor Freight mixers... Saw them on youtube and seem to get decent reviews.. Probably get a warranty with it.
The mixer size says 3.5 cubic feet.. how much concrete will fit into a 3.5 cuft mixer?
Shopguy is offline   Reply With Quote
Old 03-30-2017, 10:52 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 202
Re: Cement Mixer Question
For small mixers the capacity for wet mix is a about 1/2 that of the bowl.
http://cementmixerblog.cart-away.com...ixer-capacity/
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Shopguy (04-04-2017)
Old 03-30-2017, 11:38 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,938
Ayuh,.... Back when I was lookin' for a mixer, I had borrowed a bigger 1 like those at HF,....
A traditional lookin' cement mixer,...
The draw-back is, ya need a wheelbarrow or buckets to move the mix,....
That's why I bought a wheelbarrow style from Northern Tool, 'n Hyd....
Like these,....
Since then, I've mixed, 'n poured yards, 'n yards of concrete,...
The Trick I found is to set up a mixin' area, next to the pallet of bag mix, 'n build a little "bust the bag" table,....
Mine is made of scrap 2x4s, 'n plywood scraps, makin' it 'bout 2'x2', with a 2x4 lip all 'round the edge, except for an area the width of the mixer's hole, at the height to push the mix into the mixer,...
Pourin' the bag mix directly from the bag into the mixer is hit, or miss, at best,...
The bust the bag table allows ya to control the amount of mix, 'n get it into the drum, insteada all over the floor,....
I feel the only 2 mistakes I made buyin' this mixer is,...
I shoulda bought the plastic drum, rater than the thin light-weight steel drum,....
'n I shoulda blown the wad, 'n bought the biggest 1, insteada a smaller 1,...
landfillwizard and Bud9051 like this.
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Old 03-30-2017, 02:34 PM   #4
Rewards Points: 1,042
An 80 lb. bag of sakrete is 0.60 cubic feet.
Forgot to say 27 cubic ft. to a cubic yd.
Canarywood1 is offline   Reply With Quote
Old 04-04-2017, 05:37 PM   #5
Rewards Points: 132
I have to pour some 20 diameter columns that range from 12 inches tall (easy) to 48 inches tall.
I have a farm tractor with a loader bucket and hilo forks. I plan to mount the mixer to a skid so I can just pick the whole thing up, drive it to the sonotubes, and dump the mix in.
I have to pour about 5 cubic yards of concrete (spread out over 10 different columns) so it won't be done all at once.. We'll probably pour two columns per day, wait a day for them to dry a bit, then pour two more. Since they're all going to be interconnected by piping embedded into the concrete, allowing the first two to solidify will prevent us from prematurely disturbing them.. Maybe I'll wait two or three days in between pours.
Thanks for the info...
Old 04-04-2017, 09:08 PM   #6
Concrete & Masonry
Rewards Points: 458
Just as a note, you're going to spend more money on bagged concrete and a cheap mixer than just buying ready-mixed concrete shipped to your site. Not to mention, ready-mix concrete is superior in probably every aspect to bagged mix (quality control, larger aggregate, faster curing, often stronger, air-entrainmentfor cold climates, etc..).
On very small jobs, bagged mix can make sense financially. At 5 cubic yards, your simply "a glutten for punishment" pouring with bags.........
jomama45 is offline   Reply With Quote
Old 04-05-2017, 09:29 AM   #7
Rewards Points: 2,742
we use wheelbarrow style too - can fit in 2 80# bags at a time
Bondo likes this.
Old 04-05-2017, 10:02 AM   #8
Rewards Points: 7,780
Just using Canary's numbers, .6 ft³ per bag and 27 ft³ per yd³ you would need 225 bags for 5 yards. Would a ready-mix truck be able to get anywhere close. They will usually wait if you have some help and a few wheelbarrows. I've helped pour the concrete around a large pool in a back yard and we had to wheel it about 150'.
Bud
Bud9051 is online now   Reply With Quote
Old 04-05-2017, 10:08 AM   #9
you're near our min delivery of 6cy,,, why mix your own ? tack on some steel to your loader's bucket & place it that way,,, obviously the closer you can get the transit-mix trk, the better
Old 04-06-2017, 02:00 PM   #10
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
Definitely get a truck for that much. Rough estimates in my head put it at about 1/2 the cost, you can get it all done at once, with a lot less work. Plus, you get a mixer driver some work, and that's good for everyone.
I hate signatures.
Mort is offline   Reply With Quote
Old 04-10-2017, 01:09 AM   #11
At what point does it become economical to get ready mix vs bag? My problem is I don't want that huge truck on my driveway and can't drive on the grass because it's soft as fcuk and it's uphill. On YouTube they have pipes that can push it to where you need it. Is that a normal thing or more a commercial product?
Goodguyq is offline   Reply With Quote
Old 04-10-2017, 10:45 AM   #12
Mort's Avatar
Rewards Points: 696
Any more than a yard or so I'd get a truck. Rough math says that it's about $210 per yard if you get bags at Hombre Depot, about double what it costs in the truck. And how much is your time worth?
The "pipe" is a concrete pump, either in a boom or line pump. They start around $500 for the service, depending on region and type, but sometimes they're the only way to get it done. They'll certainly pump a residential job.
Another option is to rent a Georgia Buggy (basically a big powered wheelbarrow) if it's not too steep, and you can park the truck wherever you want.
I hate signatures.
Transition cement question jools Plumbing 2 11-29-2015 02:29 PM
Cold weather cement mixer operation Maine mixer man Concrete, Stone & Masonry 10 01-31-2013 09:56 AM
Cement mixer motor repair SKIP-1 Tools 1 10-20-2012 09:38 PM
Husky Cement Mixer jm0027 General DIY Discussions 4 12-16-2011 04:08 PM
Refacing my cement front steps - I have a question Sephora Building & Construction 9 08-08-2011 10:58 AM
