Caulk By Brick And Trim? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 05-09-2019, 12:11 PM   #1
Rewards Points: 52
Caulk by Brick and Trim?
What do you typically fill these gaps with? It is where the porch trim meets the brick.
Thanks for your help!
jdr7785 is offline   Reply With Quote
Old 05-09-2019, 02:13 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,862
Re: Caulk by Brick and Trim?
Backer rod and an sealant.
Msradell likes this.
Old 05-09-2019, 04:00 PM   #3
retired painter
Rewards Points: 864
.... and you want someone with good caulking skills to apply it.
mark sr is offline   Reply With Quote
Old 05-09-2019, 04:19 PM   #4
Still learning every day!
F250's Avatar
Rewards Points: 800
Which sealant?
Pete
Bark less, wag MORE, and Show Compassion to everyone you meet!
F250 is offline   Reply With Quote
Old 05-09-2019, 06:35 PM   #5
retired framer
Rewards Points: 16,198
urethane caulk is no fun
Do not use flat bottom gables with scissor trusses.
Old 05-09-2019, 06:47 PM   #6
Rewards Points: 988
This one works well , or Masterseal NP 1
https://www.homedepot.com/p/OSI-QUAD...2156/206156408
Canarywood1 is offline   Reply With Quote
Old 05-10-2019, 08:21 AM   #7
F250's Avatar
Rewards Points: 800
Thanks. I used that when I replaced all my windows in the house about 6 years ago, and it has held up beautifully. Didn't know if there was anything better these days, which is why I asked.
Pete
Old 05-10-2019, 08:34 AM   #8
Rewards Points: 6,771
Where brick meets trim I tend to use a clear silicone or one that goes on white and cures to clear. The latter makes it easier not to miss any spots and usually makes it paintable if needed later.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 05-10-2019, 10:19 AM   #9
retired painter
Rewards Points: 864
That would be a clear latex caulk. They can get milky colored again when they get wet but will again dry clear.
Install windows sills and trim... in brick. magnumstar Carpentry 6 07-30-2017 05:03 PM
What type of caulk is best between wood window trim and brick? shaftmaster Windows and Doors 9 04-13-2015 01:52 PM
Caulk between trim and brick? Speckert General DIY Discussions 10 02-05-2015 06:30 PM
Trim around a Brick fireplace DBarton Carpentry 2 02-27-2009 04:45 PM
Should I seal where wood trim meets the brick? megan81 Building & Construction 1 07-01-2008 12:40 PM
