Can Concrete Get Mold - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
Old 04-17-2019, 03:29 AM   #1
Rewards Points: 40
Can concrete get mold
There is a mold and moisture issue. Removing the plaster took care of the smell, but there is still moisture in areas of the rug and in the next closet. Concrete is directly under lime plaster no lath and suspect brick or something? I have pictures, is this mold or should i just focus on plaster
dcultravillain is offline   Reply With Quote
Old 04-17-2019, 04:18 AM   #2
retired painter
Rewards Points: 542
Re: Can concrete get mold
Concrete can hold moisture which is one of the ingredients mold has to have to grow, get rid of the moisture and there will be no mold. You need to stop the moisture from entering first - roof or siding.
mark sr is online now   Reply With Quote
Old 04-18-2019, 11:11 PM   #3
Rewards Points: 40
How do I know where it'ss entering? That particiular area of the wall read 24-30 on a moisture meter and there is an old pipe. I can look higher tomorrow but surroundding it it wasn't nearly as bad, not even the side that has a bubble in the plaster
Old 04-18-2019, 11:31 PM   #4
ZZZZZ's Avatar
Rewards Points: 1,628
In addition to moisture, mold needs organic material to feed on: wood, paper, anything
Was there paper, old-style horsehair, whatever as part of the plaster? If it is mold, it may just be a residual stain on the concrete.
And as Mark pointed out, your first task is to find and fix the source of the moisture.
Nik333 likes this.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 04-19-2019, 12:39 AM   #5
Rewards Points: 40
I really need to know how to do that. Do I follow the moisture meter? Go on the roof?
Old 04-19-2019, 04:19 AM   #6
retired painter
Rewards Points: 542
Your moisture meter should help. I'd visually inspect the exterior of that wall along with the roof. Some leaks are easier to spot than others.
Old 04-19-2019, 07:32 AM   #7
JUSTA MEMBER
Rewards Points: 2,416
Isn't lichen growing on a rock, some kind of a mold?
And it only needs a rock and water to grow.
So I wonder how true that is.
Just curious, not trying to be argumentative.
ED
Maybe not: Lichen definition is - any of numerous complex plantlike organisms made up of an alga or a cyanobacterium and a fungus growing in symbiotic association on a solid surface (such as on a rock or the bark of trees).
de-nagorg is online now   Reply With Quote
Old 04-19-2019, 07:47 AM   #8
retired painter
Rewards Points: 542
I've always heard that mold needs 3 things to grow; moisture, food source and heat. Remove any one and it goes stagnant.
stadry likes this.
Old 04-21-2019, 02:33 PM   #9
Rewards Points: 2,038
find the source 1st,,, THEN we'll look for a solution
Old 04-21-2019, 04:12 PM   #10
Rewards Points: 40
Thats the problem THere's a large patch area that read higher than the rest. It goe up the wall to a point then starts to go down. then it does this for some areas as well. I need more pics.
I was rearranging t his tall heavy bookshelf nothing to do with mold and decided to clean it and tipped it over and there was norway rat feces and it was very moist with wood rot underneath the carpet. They had carved a hole separate from the mouse hole I filled into the room that has the mold. This area is in between bathroom and the room with the problem. I thought I've found itt! This area didn't read high at all. Neither did the bathroom.
I think is it a leak between the toilet and shower? Do I need to recaulk? But there's no read on the meter. The moisture is there even when it oesn't rain but I dk about showers.
Points: I did some concrete filler in some holes after demolding and sanding the area and a few days later a spot turned a rusted color. Thoughts? More pics on the way.
Old 04-21-2019, 04:20 PM   #11
retired framer
Rewards Points: 14,116
There is a window in the picture.
Do not use flat bottom gables with scissor trusses.
Old 04-22-2019, 02:57 AM   #12
Rewards Points: 40
There may be a few sources. That causes mold around the frame but iit's hardd around the edges, some peeling, ower measurements. I'll take a picture and measure what I've removed that was mainly soft as well as well as give measurements and stuff. Is there another mold forum or idk someplace i can supplment
Old 04-22-2019, 03:41 AM   #13
retired framer
Windows are suspect one.
Old 04-23-2019, 04:06 AM   #14
Rewards Points: 40
]okay so i did some ****ty measurements and moisture metered the hell out of my areas. T
The problem spots average beginning where the door opens and 6 foot across and five foot up. There is a bathroom behind it. and some inches of a bookshelf. The bathroom does not go out towards the book shelf.
The area highlighted in white is filled with moisture averaging 25. I started with blue and 20 but that was too much. There are purple areas that go off the charts
Can anyone tell if this is galvanized steel or copper? Replacements were made and I don't know if it's in use, but it's moisture levels were high directly on it.
This area I did a little concrete patch repair but is that rust coming out already? three days ago.
Can concrete get mold-img_20190416_141440-1-.jpgI dont know what this is.
I have bathroom pics that are on the other sie but i am exhaused goodnight please tell me what you think.
Old 04-23-2019, 09:16 AM   #15
JUSTA MEMBER
Use a magnet to tell if copper or steel.
If steel it sticks, if copper it won't.
ED
Tags
concrete block homes , plaster crumbling , what is this?
New Concrete Over Old Concrete Pier succeed Concrete, Stone & Masonry 1 09-05-2016 03:05 PM
Is this negligent or an ok plan (mold remediation) boondocks95 General DIY Discussions 53 12-30-2015 03:26 AM
Yellow Mold - How to remove? Is this White Mold? cjaustin81 General DIY Discussions 65 11-04-2014 09:06 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
