Building Concrete Counter Top Support And Thickness Questions - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-15-2017, 05:27 PM   #1
Rewards Points: 310
Building concrete counter top support and thickness questions
I plan on building a BBQ island in the backyard under a patio. I want to make a concrete counter-top with a small bar height top in front of it.
I plan on framing a 2x4" frame, then boxing everywhere I want to put tile or ledge stone with hardy board around the sides.
I plan on shaping and pouring the counter separately and then taking the cast off and installing as it shouldn't be too big to handle. Is this ideal or would it be better to plan on pouring in place on the framing? And how would you go about pouring on the frame?
I plan on using melamine, but am unsure how thick I should make the counter. Should I just make it the thickness of the 2x4" (3.5")? Or is this overkill?
Lastly, the bar height overhang. If I pour separately and then install, What method would I use to mount it onto the wood frame?
Building concrete counter top support and thickness questions-1.jpg   Building concrete counter top support and thickness questions-2.jpg   Building concrete counter top support and thickness questions-3.jpg
bhollehday is offline   Reply With Quote
Old 06-19-2017, 09:21 PM   #2
Concrete & Masonry
Rewards Points: 458
Re: Building concrete counter top support and thickness questions
You're going to need at least 2 brackets under the upper counter top, regardless of how you pour it............
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
stadry (06-22-2017)
Old 06-19-2017, 10:26 PM   #3
Rewards Points: 138
I would concur with jomama above about needed brackets as illustrated.
In terms of anchoring, read this article. (Before seeing this, I've embedded stainless steel carriage bolts in a piece before, and that worked, but I think I like this better.)
With regards to thickness, that depends on what type of countertop system you are intending to build. I've used CHENG pre-cast products before, and they call for a minimum thickness of 1.5". I believe other pre-cast systems are similar. Given the overhang, I might be tempted to up that to 2" thick. I wouldn't do 3.5". it would be ridiculously heavy and waste materials. If I wanted it to look thicker for aesthetic reasons, I'd do a false edge.
Read this post on GFRC methods, that would allow thickness as thin as 3/4".
LanterDan is online now   Reply With Quote
The Following User Says Thank You to LanterDan For This Useful Post:
stadry (06-22-2017)
Building a support box below a kitchen desk antropovsky Carpentry 1 05-09-2015 07:17 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Lots of newbie Concrete Fountain Questions! wps74 Building & Construction 18 08-19-2009 03:08 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
