DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Concrete, Stone & Masonry (https://www.diychatroom.com/f105/)
-   -   Building a chimney (https://www.diychatroom.com/f105/building-chimney-657437/)
limiteddi 04-16-2019 11:01 PM
Building a chimney
Need an advice and some insight on a wood burning fireplace.
I somehow missed the chimney foundation requirement for the fireplace probably because it was never in the drawings. Foundation and framing is complete and I can't wrap my head around on how to build/add the chimney. The weepers are already in place and covered with gravel. I can probably dig the area where I need the foundation to be poured by now I'm hearing from my brick guy that there should be a box built inside of the house as well and that installing it "flush" with the wall and have it supported by the foundation wall is not an option. It's a pretty tight area between the wall and neighbours fence so I would need some compact bracing to be done.
Can someone shed some light on what would be the best approach here? It doesn't look like there is an easy way out of this...
Nealtw 04-16-2019 11:14 PM
Re: Building a chimney
The city will have a limit how close the foundation can be to the property line, I would start there. If it wasn't on the plan you don't want to get ahead of yourself in that direction.
limiteddi 04-16-2019 11:15 PM
I am within the allowed limit. We left extra space on the setbacks. Inspector is fine with 2.5 ft into the setback.
Nealtw 04-17-2019 12:03 AM
And that's about all I know, different designs have different requirement, we have only done the footing and foundation part so I don't know what is really the differences. Others should be along.
Msradell 04-17-2019 11:35 PM
To prevent problems in the future you will probably be better off talking to the structural engineer who did your house design. If it's not done correctly you may end up with cracking or possibly worse. It's better to spend a little money now than to have problems in the future.100
Bud9051 04-18-2019 05:02 AM
If you are encroaching on the code required setback and the inspector has said ok, get it in writing as verbal will be long gone in future years. Seen it happen.
Bud
3onthetree 04-18-2019 12:34 PM
Not sure what you're asking. The footing will be at the same depth of your basement with full height foundation walls. I've seen haunches done, but that's more difficult. It'll have to be drilled with rebars to the existing wall/footing. If you were thinking just frost-depth foundation, you don't want to put a masonry fireplace on backfill that settles.
You'll have to reroute the drain tile around it. Bore a hole for an ash dump cleanout if its going to be in the basement.
Not sure which "flush" side you were talking about, but the wall framing will need an opening to get the front of the box up to the wall. You'll also need some floor support for the hearth.
DoomsDave 04-18-2019 01:17 PM
@limiteddi , welcome!
Since you're in the process of building a fireplace, you have a golden opportunity to avoid problems caused by things like "back puffing" which is when smoke goes into the room because the flue and room opening aren't proportionally correct.
Most of the time, you're stuck with fixing the problem after the fact, but in your case there's some chance right now to make sure that things are proportioned properly to avoid trouble, like I had. https://www.diychatroom.com/f2/back-...eplace-649873/
Hope this helps.
https://www.csia.org/troubleshooting.html
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
