Brick Laying Ideas For Slanted Surface...plz Help! - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-20-2017, 11:39 PM   #1
Rewards Points: 4
Brick laying ideas for slanted surface...plz help!
New to the forum and I'm looking for ideas and opinions from people with much more experience than I have. I recently had a landscaper add a brick wall to separate our front porch and side porch. It was matching brick with our home. The brickwork on our house is 18 bricks tall and the brickwork on the pillars are 19 bricks tall due to a slope in the concrete. The top portion of both the home and pillar are level. The way he laid the brick was to match up the lines of brick starting from the bottom and then when getting to the top you can tell that the bricks were laid at a noticeable slant. Is this normal? Wouldn't it look better if the top met the walls at a consistent height? Any thoughts, ideas, or suggestions on what I should do would be extremely helpful! Thank you very much!
mikallen is offline   Reply With Quote
Old 05-20-2017, 11:46 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Brick laying ideas for slanted surface...plz help!
Looks fine to me. It follows the slope.
Probably most people would never notice unless you point it out.
Just don't invite people over that count bricks for a living.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-21-2017, 10:09 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,946
Ayuh,.... That's unconventional masonry, but I guess it's alright,...
Old 05-21-2017, 01:11 PM   #4
Concrete & Masonry
Rewards Points: 458
That would drive me nuts, but as a mason, I suppose I have a blatant bias. I see no reason not to saw the first course to make the wall level, other than either laziness or ignorance.
jomama45 is offline   Reply With Quote
Old 05-21-2017, 01:25 PM   #5
Rewards Points: 4
I appreciate the response...this is what I am looking for. I assumed this was not correct but I have no experience with brick to call out the landscaper. Pardon the ignorance on my part (I know your comment wasn't referencing me), but to do this correctly the first row or couple rows of brick should have been cut to make the ground level? Or is this done with the mortar? Thank you!
Old 05-21-2017, 02:38 PM   #6
Rewards Points: 138
Agree with Jomama. I'm a bricklayer as well and you would normally count down the courses from the top and make the cuts in the footings or base.
Only way to correct it is to take it down and rebuild it. Structurally it's not a problem.
But if you don't like the way it looks you need to change it.
stuart44 is offline   Reply With Quote
Old 05-21-2017, 02:57 PM   #7
Concrete & Masonry
Rewards Points: 458
The only correct way (IMPO) is to rip the brick on long angles. The first few brick on the high side would be so small that mortar would be easier.
Any chance you have a twin brother named "stuart45"?
Old 05-21-2017, 03:04 PM   #8
Rewards Points: 138
Wink
Thought I'd have name change Joe. Actually I couldn't work it out when the passwords got reset and gave up and came back a year younger.
Old 05-21-2017, 03:46 PM   #9
concretemasonry's Avatar
Rewards Points: 2,716
How does the wall look from the other side?
If you are satisfied, just live with it.
Dick
concretemasonry is offline   Reply With Quote
Pros please help - what method attach porch roof to brick veneer dinoburger Concrete, Stone & Masonry 6 08-02-2015 11:57 AM
Bonding agent, Mortar and grout for tiling over a brick patio soversen Concrete, Stone & Masonry 4 06-26-2015 09:32 PM
Cleaning & Sealing Red Brick JasonCA Concrete, Stone & Masonry 3 01-23-2013 12:56 PM
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 03:22 PM
Any ideas on how to match height of two surface counterop? pgnadi General DIY Discussions 8 02-22-2011 11:59 AM
