Braking Concrete - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree18Likes
Old 05-28-2019, 06:29 PM   #16
Rewards Points: 8,964
Re: Braking concrete
Yodaman had an easy time with an electric jackhammer. I had a hard time with one. I think the difference is in the thickness of the concrete. I can believe a jackhammer will have an easy time through 3" slab. Mine was maybe 10" thick. I am predicting OP will have a real fun time with that footing --- hope that's 12" wide, not 12" deep.
SPS-1 is offline   Reply With Quote
Old 05-28-2019, 07:56 PM   #17
retired framer
Rewards Points: 4,344
Depends on the quality of the concrete.
mark sr likes this.
Do not use flat bottom gables with scissor trusses.
Old 05-28-2019, 10:38 PM   #18
DoomsDave's Avatar
Rewards Points: 8,358
Breaking up concrete is never easy, like breaking up a concreted relationship.
DoomsDave is online now   Reply With Quote
Old 05-29-2019, 05:53 AM   #19
retired painter
Rewards Points: 1,362
Several yrs ago I tore down a 150 yr old house that had a bath rm added in the 80s. It was in a small addition on a 4" concrete slab. I thought I'd pull it up with my tractor bucket, that didn't work so I attacked it with a sledge hammer and couldn't even crack it. A backhoe struggled but did get it up.
Nealtw likes this.
mark sr is offline   Reply With Quote
Old 05-29-2019, 06:15 AM   #20
Rewards Points: 2,698
bosch sds max will make 1 1/2" holes,,, cheaper & faster ? rent bosch brute 60# for breaking,,, seems to me your bigger issue is funding this work
Yodaman likes this.
Old 05-29-2019, 10:12 PM   #21
Rewards Points: 233
Here is what I need to break.
thunderhead is offline   Reply With Quote
Old 05-30-2019, 12:26 AM   #22
Rewards Points: 992
...and the age. Concrete continues to harden for many years. It's much easier to drill new concrete vs old.
Breaking up concrete is never fun. Years ago I did a patio tear out where the slab was tied in to the foundation. We cut back the pad with a wet saw to get a straight line along the foundation, then we started breaking up the 4" slab only to find another 6" slab under it. At that point we called in the machine ops from down the street to have at it with their excavator. Half way through pulling up the 4" and 6" slabs they found another 8" slab under half of the patio! I'd still be there to this day chipping away at all those layers if we didn't bring in the excavator.
SPS-1 and Nealtw like this.
NotYerUncleBob2 is offline   Reply With Quote
Old 06-22-2019, 01:16 PM   #23
Rewards Points: 233
Done! I rented a makita electric jack hammer. The bottom was easy but those sides were a major pain! They turned out to be about 2'. Took me 7 hours but I finally got it.
Braking concrete-img_20190614_152944.jpg   Braking concrete-img_20190614_103215.jpg
bob22, SPS-1, Msradell and 2 others like this.
Old 06-22-2019, 02:14 PM   #24
Property Mgt/Maint
Rewards Points: 7,380
Good job. A little concrete will never be a obstacle for you again.
Msradell likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
thunderhead (06-22-2019)
Old 06-23-2019, 10:00 AM   #25
Rewards Points: 1,700
I bet you're still tingling.
SPS-1 likes this.
huesmann is offline   Reply With Quote
