Best Way To Fix Foundation Extension - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By tstex
Old 03-20-2019, 08:58 AM   #1
Rewards Points: 1,986
Best way to fix foundation extension
Hello to all,
I did an extension to our farm house in 2002. The original pier and beam was poured in 1950. When I did the extension, also just a perimeter foundation, they dug down about 2 ft, appropriate rebar and doweled in to the existing foundation. The soil is a very sandy loam 4-5 ft, then clay. I think the width of the pour is 8-9 inches. No piers were done, which I now regret.
You can see the crack from where the two diff concrete pour separated, but the old foundation has also cracked. Since we also have really bad terminates in the area, I want to close the gaps. First pic is a close-up, the second is further back.
Here's my questions:
  1. What can I best do to fill the cracks?
  2. What is the process to fix them?
  3. What product(s) do you recommend I use?
  4. Other?
Thank you very much.
Best way to fix foundation extension-foundation.jpeg   Best way to fix foundation extension-foundation2.jpeg
tstex is offline   Reply With Quote
Old 03-20-2019, 03:27 PM   #2
Re: Best way to fix foundation extension
Hey guys,
I'm heading out tomorrow and was hoping to get a little direction on this...
What about some kind of quikcrete caulk that I could press into the cracks, then hit it w my air compressor to go into the crack further. Then when no more would go in, I'll just trowel it smooth. Wait a week and then come back and it it again for any shrinkage...is this plausible?
Old 03-20-2019, 03:35 PM   #3
retired framer
Rewards Points: 11,906
There are people that do this stuff but if they are not around, the rest of us would be just best guess.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 03-20-2019, 03:37 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,548
I guess your concern is to prevent termite migration and not any structural concern.
Assuming your foundation wall is probably 8" wide, I do not know a sure method to inject that crack completely to block termite migration.
I think I would treat it intermittanly with a good termiteacde.
IDK
Good luck
MTN REMODEL LLC is offline   Reply With Quote
Old 03-20-2019, 04:51 PM   #5
Thanks Neil and MTN...I might have to dug down and out 2 ft from the cracked wall to see how far it goes down? Also, the cracks are pretty narrow and I doubt I could get a credit card in there, so I might have to chisel out some loose concrete and go a bit deeper to get a nozzle in there, or maybe even drill a 1/8" masonry bit into the cracks for deeper penetration of any type of compound.
What do you guys think? I like the tip in the video to wet the existing concrete so the old would not suck out all the water of the filler - I would not have done that.
Thanks, tstex
Old 03-20-2019, 04:59 PM   #6
retired framer
Thanks, tstex
The foam was just a filler, I wouldn't go that deep, about an inch maybe more unless you find a void.
Old 03-20-2019, 05:08 PM   #7
ok, thanks Neal
Nealtw likes this.
Old 03-20-2019, 05:34 PM   #8
Rewards Points: 888
Why not do it right the first time and be done with it?
https://www.emecole.com
Canarywood1 is offline   Reply With Quote
Old 03-22-2019, 09:12 AM   #9
thanks Canary - I have a call into emecole
Concrete foundation for damming spring Pack25 Concrete, Stone & Masonry 4 08-10-2018 05:53 AM
No Footer Beneath Foundation Wall Adam Sinke Building & Construction 5 07-24-2018 03:12 PM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 02:51 AM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
