We had a 24x36 barn/shop erected on our 1.5 acre lot. 1/3 shop (mine) 2/3s barn (hers). The floor slab was floated to a "garage" quality. And the wife had been moaning about the horses slipping on the concrete. Stuff and nonsense really but they're her babies.
What to do? I am suggesting an epoxy paint over the concrete. Opinions?
I know your pain... My wife thinks just about everything is going to end up killing our (ok, her) horse. Just finishing building a much smaller shelter - about 12' x 12'.
I'm leaving mine dirt for now, then then probably switching to one of those gravel grid things if needed.
Since you already have concrete... I'm thinking the rubber mat might be best, although that's going to run you over $1,500 for a single sheet the size you need.
I wouldn't expect it to hold up long term. I'd expect the horse to cause some holes which wouldn't be a major problem themselves, but when you have water and dirt getting in there, it's probably going to start peeling.
Every horse owner has their own ideas what's best for their kids, but in my opinion rubber barn mats are the way to go. You don't need to cover the entire floor - we just did the stalls and down the centre of the 'shed row' (i.e. the common area in front of the stalls to/from the doors to outside). The ones we used were 4'x8' (ish, I don't really remember). We might have bought a few new but most of them were used, sourced from other owners/barns, etc. If nothing else, most horse communities are very connected.
Even better if you know somebody connected to the industrial conveyor belt world. We had a friend who was and got a ton of gently used very wide belting for very little.
Buy an extra for yourself as a stress mat for where you stand working at your tools.
Conveyer belt is most slippery with a little water, don't use it for horses.
The reconstituted mats are fine, they have a rough surface and are much less dense.
Not sure where you are located but around here, Tractor Supply sells rubber stall mats for this very purpose. They usually go for about $35 for 4'x6'x3/4" thick. I bought them for a ball stop for the batting cage in my basement and to stand on when hitting. Works great. Very rubbery smelling for a while but the horse odors probably overpower their smell
Very heavy and heavy duty. They weight a little over 100 lbs each.
used to make good $ cutting grooves into barn conc floors so cows wouldn't slip & fall,,, even modified a couple 65hp saws to cut 2" o/c,,, then we bought scarifiers - much better cow/horse traction - cheaper to run - more profit, too :smile:
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
